Sweet ride, meng~ mine should be here by the middle of Aug., so says ASL...
My PHB Denim blue is up for grabs if you know anyone interested! I've had someone behind me for it for years, but just before the sale happened he got cleaned out and now can't think about a new car. Thank Patos for our situation...
Here are the specs:
Denim Blue PBH Audi TT 180FWD 5fwd Manual for sale, 83,500kms. Much loved and pampered car, fully serviced only by Automobile Sales Ltd. in POS. Black leather interior, factory Bose stereo with 6cd changer, colour matched headlights, Oettinger 2-piece 18's with 235/40 Toyo T1R Proxes all round (two new ones installed this Saturday), Zimmermann drilled rotors in front, Brembo solids in back, Porterfield pads.
Complete new suspension Aug '07 (bilstein HDs front & rear, Audi sway bar links, front and rear upper strut mounts & perches, ECS tuning polyurethane bushings throughout), timing belt kit done at the same time as per factory scheduled requirements (new belt, roller tensioner & assembly, idle roller, water pump with metal impeller, accsy drive belt, thermostat & housing, motor mount bolts, camshaft and crankshaft seals). Have used Mobil 1 exclusively since the day I got it.
Also: Hyperboost DV valve from Stratmosphere, Spec stage 1 clutch (installed by Audi late 2006), interior headliner had a part that was sagging and was changed in March 2008. The AC evaporator had a slow leak and the complete unit was replaced at same time (factory parts in both cases).
The car has been extremely well looked after, doesn't have a single door-ding, and it spotless inside. I've spent a fortune on making sure that any replacement parts were either factory-supplied or better... the car is a design classic and never fails to turn heads.
Price: $140,000 or best offer, no VAT payable. I can be reached on 380-1261, (Rodney)
