Switch to full site
Discuss all things to do with the MK1 TT 8N (1999-2006)
Post a reply
TT Lock Switch -opinions on creating a fix. Got 1 option
27 Jan 2006, 08:05
HELP NEEDED!
Another not so clever design but maybe we can come up with a solution.
basically a nylon cover wears and the exposed switch head cuts into the latch coating stopping the latch working fully and eventually not having enough to push the switch.
The Switch is mounted with a spring clamp and located with two plastic pins from the body from the body of the switch
NOTE: in the above, there is a metal tab holding the spring clip, this is revised, all earlier locks dont have that, the clip T edge rests against the plastic switch pins to keep it in place.
1. A weatherproof roller switch is going to be a much better option.
2. a little sanding of the damage should recover the latch to allow a roller to work
(or am I flogging a dead horse?, maybe a little epoxy and sanding?)
3. the side shown above must remain fairly flush as that side is close to the bodywork.
4. the switch is a normally open circuit switch, press to make contact.
5. I need some ideas on the switch type and mounting options.
more reference pics.....
27 Jan 2006, 13:05
Here you go Wak:
Farnell part:
http://uk.farnell.com/jsp/endecaSearch/ ... =gensearch
Clearer datasheet:
http://www.farnell.com/datasheets/26701.pdf
The roller type will take up too much room - they all fall into standard sizes. The roller itself is a 5mm diameter wheel requiring at least 7mm or so room when compressed compared to not a lot with the simple plunger type. So you'd have to back off the body mounting accordingly. Added to that the problem that the roller sticks out, so doesn't operate in the same position on the cam.
The microswitch I'm suggesting is a lever type. What you could do is bend the lever at the end around the switch so it simply forms a protector for the plunger beneath and doesn't catch on anything. The lever would slide on the rough cam surface like a ski/sledge. The operating position will be near identical and the mounting position would be the same.
I think what you could do is smooth out the torn up nylon a bit then mount the switch using two M3 screws washers and lock nuts (or back to back nuts to lock).
The switch is a changeover so normally open or normally closed depends on how you connect the wires.
It's fully sealed to IP67 (immersion in water) and costs a reasonable £3.81 +VAT. Hope that helps :)
P.S. I still think the surface looks as though it's been ripped up by something else, like the end of a too long mounting screw or something - it just doesn't look gradually worn away - more torn with force.
27 Jan 2006, 13:41
Cheers John,
I shall get hold of one and see how it could be used.
Shame a roller cant be found I wonder if the SKI effect will also cut into the plastic only thing is the metal lever could be bent to compensate!
27 Jan 2006, 13:43
Hurry up Wak, I need my doorlock fixed :wink:
27 Jan 2006, 20:32
Does this help clarify? The cam still presses the actuator button in exactly the same place but the lever is bent out of the way and merely protects the sealed actuator from friction damage and presents a smooth surface to the cam. The thicness of the lever is negligable, the switch mountings are the same dimensions and fitted the same way round as before, with the actuator button in the same position - so the actuator linear movement is the same.
If the switch is mounted the other way round and the cam presses the free end of the lever the linear movement of the actuator, due to leverage, will be too little. The same problem occurs with the roller type - the roller would need to be directly above the actuator, for the same movement, but it's at the other end, losing ~3x the linear movement. You also need the extra space of the roller. Although it would be possible to adjust the switch mounting position - the reduction in the linear movement would make it tricky to adjust and set up reliably.
09 Feb 2006, 09:13
Thanks for the info Wak. Excellent photos too.
Have you made any progress with this? Any luck sourcing a suitable replacement switch? I might be able to get hold of some military spec micro switches which are weatherproof but also have metal plungers rather than the flimsy plastic type.
I'll take a look through my catalogues later to see if any are the correct dimensions. Just out of interest how critical are the dimensions. Is the switch a tight fit or could it accommodate something slightly larger?
Andy.
09 Feb 2006, 09:36
Andy, I am a little involved in this too as we had an issue with mine failing, we swapped it over at the weekend with a second hand one which is ok for the moment.
Symptoms are...
Window dont drop the 5 mm on opening
Interior light dont come on when door opened
Lights on warning buzzer dont work
Car will lock itself with keys in ignition if you close the door and dont start up (it actually locked me out with the keys inside)
Instrument lights dont light up when door opened
Personally I think a metal retracting pin will wear into the cam even more than a nylon one but then what do I know.
Thanks for the suggestion though Andy , you may be right !
09 Feb 2006, 10:50
Hmm, you could be right there John. Also available are metal plunger types with metal levers similar to the one pictured earlier. These might be even better but maybe overkill.
Those are certainly the symptoms I have too. Although I hadn't considered the problem with being locked out. That might be the encouragement I need to do something about it. Until now I'd just seen it as a mild annoyance that the windows don't do their cool little dropping thing when you open the door.
Andy.
09 Feb 2006, 12:51
I have the recommended switches and it looks like it would work well but they are deeper, I have a working prototype but the switch sits in the clip loosly.
I am trying to to decide on a mounting option that is better and will be more solid that isnt going to involve epoxy resin! :roll: :)
I think the metal clip wont be too bad and the beauty is if it does wear a little plastic it can be bent further to take up the slack.
09 Feb 2006, 13:07
Do the holes in the switch line up with the existing holes in the catch casing? Would it be possible to bolt them through and do away with the metal clip? How about drilling a new set of holes if they don't line up perfectly?
Andy.
09 Feb 2006, 13:08
TTotal wrote:Andy, I am a little involved in this too as we had an issue with mine failing, we swapped it over at the weekend with a second hand one which is ok for the moment.
Symptoms are...
I have exactly those symptoms, and have been looking for a fix. I've been quoted over £200 to get it fixed at a local garage (specialising in Audi/VW), and i'm guessing its gonna cost a good deal more from Audi themselves? Anybody had a quote from Audi?
09 Feb 2006, 13:18
Andyman wrote:Do the holes in the switch line up with the existing holes in the catch casing? Would it be possible to bolt them through and do away with the metal clip? How about drilling a new set of holes if they don't line up perfectly?
Andy.
no, the switch is deeper so the catch metal covers the holes!
09 Feb 2006, 13:34
Symptoms are...
the lock is around £82 and about an hour to change over.
09 Feb 2006, 13:49
Andy.
Doesn't that mean you could just re-drill the holes and bolt it on with some M3 machines screws?
I found a possible alternative which might fit better but is slight more expensive.
http://rswww.com/cgi-bin/bv/rswww/subRa ... cheID=ukie
Andy.
09 Feb 2006, 14:10
Wak wrote:
Symptoms are...
How easy is it to do? idiots guide? and where to get the lock from?
Post a reply
