Bytes and Bits
571K views 2.7K replies 364 participants last post by  John-TT
#1 · (Edited by Moderator)
I open a thread where ask questions about coding, or if you need help with electrical schemes or how to remove parts of the car.
Summary:
-DRL brightness while turn indicators are on
-High Beam Assist
(until my16, my17 is being tested)
-Coming/Leaving home
-Disable the open door sound while the engine on
-Adjust the time length for the step 3 heating seats
-Adjust the temperature thresholds of any step heating seats
-Coming/leaving home Without Low Beams,just drl
-Enable acoustic signal locking/unlocking the car
-Delay window rolling power when opening door
-Visual acknowledgment when all doors are locked/windows closed
-Show the parking radar on the left side of the cockpit when we put in reverse
-Increase the led intensity (when low beam are on)
-Increase the led intensity (the same above but when coming/leaving home is active)
-Third brake light always on or only with drl/low beam on
-Rear stop blinking (together or opposite) with the turn indicator
-Rear turn indicator blinking (together or opposite) with the rear fog light
-Change how many days in advance you receive the service countdown alarm
-Turn down the passenger mirror in R
-Deactivate fasten belt sound and symbol
-Enable g-meter
-Set the exhaust valve often open
-Laptimer
-Turn indicators, number of blinkers
-Traffic signs recognition
updated '17
-Disable automatic reset for the auto high beam assist
-Emergency flashing indicators when brake
-Enable/disable drl via mmi
-change the speed activation and deactivation of auto full beam
-Change the length/delay time of the headlight washer
-Change the sound actuator volume
-Add red zone in the revs counter, font numbers like TTs and logo TTs/TTrs
my15-my16
-Automatic closing windows when raining after Park
-Copy a mp3 cd from the MMI unit to the jukebox
-Differential lock threshold
-Close mirrors when we lock the car
-Disable auto engaging parking sensors in traffic
-Automatically car closes by itself when we close the door with engine and ignition off
-change quality oil for service DIY
-Map of any light in the car
-Fix an error that causes the "number of keys paired to the car" info disappear after some coding
-Lock the car with the engine on
-Service position front wiper on MMI
-Disable start&stop system
-show the oil level on the MMI
doesn't work on the TT
-Enable torque and power graph from TTrs if they appear, don't work before my18
>>Under testing<< Coding that you can test but I can't guarantee they will work like the other above
-unlock video in motion
-expanded electronic differential threshold
-air recycle sensitivity
-counter steer force
1 engine
2 auto transmission
3 abs
5 access/start authorization
5F info electrics
8 auto hvac
9 central electrics
10 park/steer assist
14 susp. electr.
16 steering wheel
17 instruments
42 driver door (may be inverted with 52, I have RHD)
52 passenger door
55 headlight range
A5 front camera
Unit 9
adaption
"(18)-Leuchte2SL VLB10-Dimmwert GH 2,0" set the value to your choice, I suggest 30, 100 is the max
"(18)-Leuchte3SL VRB21-Dimmwert GH 3,0" set the value to your choice, I suggest 30, 100 is the max
"(18)-Leuchte4TFL LB4-Dimmwert GH 4,0" set the value to your choice, I suggest 30, 100 is the max
"(18)-Leuchte5 TFL RB32-Dimmwert GH 5,0" set the value to your choice, I suggest 30, 100 is the max
if you want the DRL pulse on in the instant the turn indicator is off:
Unit 9
adaption
(16) leuchte 3.....G3 change from blinken rechts activ (beide phasen) to blinken rechts dunkelphase
-High Beam Assist (with or without light sensor, front camera required, until my16) password required, ask me
View attachment HBA.pdf
EDIT (Barmybob): It could be this document, now stored on the forum High Beam Assist TT.pdf if this is incorrect please let me know.
thanks to who helped me test it:
Ignorer
tommyknocker
stumardy
-Coming/Leaving home (for TT with xenon) password required, ask me
View attachment Coming Leaving home xenon.pdf
-Disable the open door sound while the engine on thanks to audinut
Unit 17
Adaption
Find in the menu:
Ignition active message; actuator
change to "No display"
-Adjust time length for the step 3 heating seats
set after how many minutes the seat heating will pass from step 3 to step 2
Unit 8
adaption
..seat level 3 to level 2 change the value to your choice, standard is 10 minutes
additionally, we can adjust the time from the step 2 to step 1
--seat level 2 to level 1 change the value to your choice, standard is 0 minutes
-adjust the temperature thresholds of any step heating seats
Unit 9
security access 31347
adaption
find in the menu:
(1) to (12) seat heater level current consumption allocation..
change the value to your choice, even different per each side of the car
1 untere, min temperature step 1 left side (driver to me) standard is 18
1 obere, max temperature step 1 left side standard is 20
2 untere, min temperature step 1 right side standard is 18
2 obere, max temperature step 1 right side standard is 20
3 untere, min temperature step 2 left side standard is 26
3 obere, max temperature step 2 left side standard is 28
4 untere, min temperature step 2 right side standard is 26
4 obere, max temperature step 2 right side standard is 28
5 untere, min temperature step 3 left side standard is 34
5 obere, max temperature step 3 left side standard is 36
6 untere, min temperature step 3 right side standard is 34
6 obere, max temperature step 3 right side standard is 36
-coming/leaving home Without Low Beams, just drl thanks to berk192
Unit 09
Security access 31347
Adaptation
Find in the menu:
(10) -Leuchte6ABL LC5-dimming 6 Select CD
Adjust value 127 to 0
(11) -Leuchte6ABL LC5 dimming Direction CD 6 Select
Adjust value to minimize
(10) -Leuchte7ABL RB1-dimming 7 CD Select
(11) -Leuchte7ABL RB1 Dimming Direction CD 7 Select
-enable acoustic signal locking/unlocking the car (posted by ZaniCWD, tested and changed by me)
this coding enables a "big" from the "original Audi alarm" or, if you don't have it, a signal with the car's horn..a bit spooky and noisy in the night but there is the menu on the vc to activate/deactivate this option
Unit 9
Security Access 31347
Adaption
find in the menu:
(1) Acknowledgement Signals - Akustische RĂĽckmeldung verriegeln change to active (signal when lock)
(2) Acknowledgement Signals - Akustische RĂĽckmeldung entreiĂźen change to active (signal when unlock)
(3) Acknowledgement Signals - Dauer der Akustischen... keep in normal with the original alarm, change to kurz to short a bit the sound
(7) Acknowledgement Signals - Menuesteuerung akustische Rueckmeldung change to active (enable the menu on the vc)
(8) Acknowledgement Signals - Akustiche Rueckmeldung global change to active
(9) Acknowledgement Signals - Akustiche Rueckmeldung signalhorn change to active (show the menu on the vc)
(this will retain the power so you can roll up /down window with button after ignition off and door opened)
Unit 9
adaption
(14)-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen change to inactive
Visual acknowledgment when all doors are locked/windows closed tanks to ZaniCWD
keeping pressed the closing button on the key fob, we'll close the windows and once closed, the car will blinks the indicator lights
Unit 09
Adaptation
(5) Acknowledgement Signals - Optische Rueckmeldung Komfortschliessen change to active
-show the parking radar on the left side of the cockpit when we put in reverse
Unit 10
Security Access 71679
Coding
Byte 02
Enable Bit 0
Unit 9
Adaptions
Find in the menu:
(6) Leuchte 2SL...dimmwert AB Change the value from 28 to your choice (I use 50)
(6)-Leuchte3SL...dimmwert AB Change the value from 28 to your choice (I use 50)
Unit 9
Adaptions
Find in the menu:
(10) Leuchte 2SL...dimmwert CD Change the value from 28 to your choice (I use 50)
(10) Leuchte 3SL...dimmwert CD change the value from 28 to your choice (I use 50)
This coding allows to have the third brake on with an intensity of your choice, obviously if you brake, the light is the standard 100%
Unit 9
adaption
find in the menu:
8 Leuchte22BR MA57 Lichtfunktion C 22 change the value from not active to:
-active 100%, the light will be always on, in any position of the light switch, even if you turn off drl from the menu and it'll remains on about 20 second after locked the car. it's always on and stop!
-standlicht allgemein, the light will turn on when low beam lights come on in auto or if you turn on manually position lights or low beam lights.
the third light will be off during the day with the drl
10 Leuchte22BR MA57 Dimmewert CD 22 change the value from 0 to your choice (100 is the max intensity of the third light, my advice is 5)
if you want the third light always on but, it's possible to deactivate it when the light switch is on 0 and you turn off drl from the drl menu, it's on with the light switch on auto, position and low beam and won't remain on after locked the car, do this coding.
8 Leuchte22...C22 change from not active to standlicht allgemein
9 Leuchte22...D22 change to daytime running lights
10 Leuchte22...CD22 change to the value from 0 to your choice (100 is the max intensity of the third light, my advice is 10)
-rear stop blinking (together or opposite) with the turn indicator
Unit 9
adaption
find in the menu:
stop together the indicator
(8)-Leuchte20BR LA71-Lichtfunktion C 20 change the value to Blinken links Hellphase (left stop)
(8)-Leuchte21BR RC8-Lichtfunktion C 21 change the value to Blinken rechts Hellphase (right stop)
stop opposite the indicator
(8)-Leuchte20BR LA71-Lichtfunktion C 20 change the value to Blinken links Dunkelphase (left stop)
(8)-Leuchte21BR RC8-Lichtfunktion C 21 change the value to Blinken rechts Dunkelphase (right stop)
-rear turn indicator blinking (together or opposite) with the rear fog light
Unit 9
adaption
find in the menu:
(8)-Leuchte26NSL LA72-Lichtfunktion C 26 change the value to Blinken links Hellphase (left rear fog light)
(8)-Leuchte27NSL RC6-Lichtfunktion C 27 change the value to Blinken rechts Hellphase (right rear fog light)
(8)-Leuchte26NSL LA72-Lichtfunktion C 26 change the value to Blinken links Dunkelphase (left rear fog light)
(8)-Leuchte27NSL RC6-Lichtfunktion C 27 change the value to Blinken rechts Dunkelphase (right rear fog light)
you know how it works!
this coding is also possible with the reverse light but I don't like it! for who wants to try...
(8)-Leuchte28RFL LC11-Lichtfunktion C 28 change the value to Blinken links Hellphase (left reverse light)
(8)-Leuchte29RFL RA64-Lichtfunktion C 29 change the value to Blinken rechts Hellphase (right reverse light)
if you want to blink the reverse light opposite the indicator, change Hellphase to Dunkelphase
-since rear stop lights are very bright, if someone wants to activate this coding, I suggest to reduce the light intensity, read below
in any coding, you can read the letter C (C20,C21,C26 etc)
Below you can find "...Dimmwert CD.." insert here the intensity of the light that you prefer, 100 is the max
Unit 17
adaption
find in the menu
Service notification in days and change from 30 days to your taste
-turn down the passenger mirror in R
Unit 52 (select the passenger unit, it may vary from left drive hand/right drive hand)
coding
Byte 4
enable bit 2
enable bit 3
-deactivate fasten belt sound and symbol
Unit 17
Adaption
find in the menu "Disable seat belt reminders"
change value to "yes"
-enable g-meter (from TTrs) thanks to elboobio and his eleven obd
Unit 17
Coding
Byte 10
enable Bit 2
it should appear next to the lap timer function but not all cars are compatible, it can be activated but couldn't work or doesn't appear at all!
-set the exhaust valve often open I say often because many cars already have this bit deactivated, but the car manages the valve anyway. Best solution is to unplug its connector but with the error on the vag scan
Unit 01
Coding
Byte 9
disable Bit 2
-laptimer
Unit 17
coding
byte 1
Enable Bit 3
-turn indicators, number of blinkers
Unit 09
adaption
find in the menu "Turn signal control - komfortblinken blinkzyklen"
Possible values: "2-5"; Default: "3"
change in a value of your choice
-traffic signs recognition, it's required front camera and and navi. without navi, VC will give an error but the coding works anyway
Unit A5
Security Access 20103
Coding
Byte01
Enable Bit 0
Adaption
find in the menu "display end of speed limit symbol" change the value to "active"
find in the menu "display no passing allowed" change the value to "active"
find in the menu "road sign detection fusion mode" change the value to "fusion"
find in the menu "display valid additional signs" and check if the value is 00100111
Unit 17
Coding
Byte05
Enable Bit2
Traffic signs menu on the vc isn't available in the Europe market
Reset the MMI
the road signs on the map is provided by the map in your car, so if you don't have traffic signs rec, you'll have the speed limit anyway but, of course, could be not updated with the current speed limit.
the speed limit on the bottom instead, is supplied by the front camera, updated with what it read (so sometime they can't match the same speed) and it's shown there where you are in any screen on the VC
View attachment 1.tiff
Unit 9
Access 31347
Adaption
find in the menu "channel 5 assistance light functions-Fernlichtassistent reset"
Change to not active
Now everytime we turn off the car and then on, the high beam assist will remain active
sometime can happen that the car reset the control anyway but the symbol auto is still on
-emergency flashing indicators when brake
if we have and emergency brake at a medium-high speed, emergency indicators will blink for a while
Unit 9
adaption
find in the menu:
(18) Dynamic turn signal modes - emergency alert blinken change to active
-enable/disable drl via mmi
Unit 9
adaption
find in the menu:
(2) Daytime Running Lights - Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich change to active
Unit A5
Adaption
find in the menu "activation speed for high-beam assistant"
standard value is 57 km/h, set your speed then ok
find in the menu "channel speed threshold for high beam recommendation off"
standard value is 27 km/h, set your speed then ok
I use 10 and 12..the car uses a tolerance so it doesn't really use those speeds but a bit more
In the same menu, there is night vehicle activation/deactivation detection brightness..
Activation, original value 3lx, if you decrease it, full beam will turn on lately, more far from to the car in front of you..and vice versa if you decrease the value
Deactivation, original value 20lx, if you increase it, full beam will turn off lately, more close to the car in front of you..and vice versa if you decrease the value
-change the length/delay time of the headlight washer
headlight washer come out "after 1 sec with the respective lever pulled back" or "after 8 times we pull the lever (for less than a sec)"
we have few parameters to change depending from how do you like:
Unit 9
adaption
find in the menu:
(1) windshield wiper - anzahl betaetigungen.......aktivierung (how many time we have to pull the lever to activate the headlight washer) change the value from 8 to your choice
(2) windshield wiper - sra verzoegerungszeit (is the delay time before the headlight washer come out, is the 1 sec I talked about above) less is the time, before we have the spray
(3) windshield wiper - sra waschzeit (is the length time of the headlight washer spray) originally set to 700ms change the value to your choice
-change the sound actuator volume
Unit A9
Adaption
find in the menu actuator volume, default is 100%, change the value of your choice
-Add red zone in the revs counter, font numbers like TTs and logo TTs/TTrs when turn off the car
this byte 9 is dedicated to the screen logo, any bit is a different model (depending from the car A3->S3->g-tronic A4->S4->RS4 etc), but I can't see the labels.
For TT (only 1 flag has to be ticked, no combinations):
Unit 17
Byte 9
enable bit 0 red zone + logo TTs
enable bit 1 red zone + logo TT (my 2014/2015)
enable bit 1 red zone + logo TTrs (my 2016)
enable bit 1 + 2 red zone + logo TT (my 2016)
reset the MMI and leave the car locked for a while
For TTs (only 1 flag has to be ticked, no combinations):
Unit 17
Byte 9
disable bit 0 and enable bit 1 red zone + logo TTrs (my 2016)
(thanks to tommyknocker's)
Unit 9
adaptions
find in the menu:
(15) Access control 2 Regenschliessen_ein aus change the value to active
(16) Access control 2 Regenschliessen_art change the value to permanent
(28) Menueusteureung Regenschliessen change the value to active (doesn't appear on our menu)
do a MMI reset
select the drop menu on the top and select the number 2 RLFS
change the coding from 00005D to 07005D
#2 · (Edited by Moderator)
-Copy a mp3 cd from the MMI unit to the jukebox, standard we can copy data only from usb or sd
Unit 5F
Coding
Byte 24 enable bit 5
Unit 5F
Adaptions
Find in the menu: "(2) copy multimedia data optical drive" change the value to on
in a bend, the car will brake the internal tyre with the major unload so to help the driver to keep the apex
the value is expressed in threshold so, low threshold is the major help the car gives to you and high is the less help.
Unit 03
Adaptations
"Expanded electronic differential lock"
change the value to "Medium", "Not activated", "Low", "Medium", "High"
default is medium
Unit 9
Adaptions
find in the menu
"(24) - Access control2 funk Spiegelanklappung modus "
change the value to
-1 if we want close mirrors when we lock the car
-2 if we want close the mirrors only pressing the lock button for few seconds
They'll automatically turn on when you put in R or press the sensors' button (thanks to ... for the update)
Unit 10
Security access 71679
Coding
Byte 3
Disable bit 4
-automatically car closes by itself when we close the door with engine and ignition off, only for advanced key
The lock is partial, limited to the doors and doesn't activate the alarm
Unit 5
coding
byte 2
enable bit 4 (close with slamming door)
security access 20103
Adaption
(5) internal_passive_entry_exit_....door_slam_lock change to active
resetting the service interval, the car could switch to poor oil quality and showing half of km remaining
Unit 17
adaption
find in the menu:
ESI: oil quality change to good oil quality
-map of any light in the car
I've created this map for who wants to know more about the unit 9...don't mess up too much with these parameters because they manage all the led functions in the car.. (contact me if something is different or wrong, I based it on my car)
View attachment led map.pdf
-Fix an error that causes the "number of paired keys to the car" info disappear after some coding
in the service menu, car info, there are the number of keys paired to the car (2 remote with one only key), this info could disappear after some coding, here how to restore it
Unit 5F
adaption
find in the menu
(161).......adaptive_key
(163).......adaptive_key_over_threshold_high
change both to active and do a MMI reset
just to be sure, even if this value won't change itself (unlike both above), check these
(11) car function list CAN adaptive key check if it is available
(12) car function list CAN adaptive key msg bus check if it is terminal 15
Unit 9
adaption
(1) Access control Funk bei klemme 15 ein change to active
-Service position front wipers on MMI
(Changing only the adaption in the 9 should be enough since the other parameters are already on)
Unit 9
Adaption
find in the menu (13)-Windshield wiper-Menuesteuerung Frontwischer and change to active
Unit 5F
Adaption
find in the menu:
(23) Car function list BAP Gen2 wiper_comfort_0x0C" change to active
(61) Car function adaptions menu_display_wiper" change to active
(63) Car function adaptions menu_display_wiper_over_threshold_high" change to active
sometime the value doesn't change but it's set anyway
-disable start&stop system (thanks to david.beeston)
Unit 19
Adaptation
find in the menĂą "Start Stop Voltage Limit"
Default Value is 7.6 (or was on mine)
Set the new value to 12
check the oil level in the service menu (it may remains grey)
Unit 5F
adaption
(91)-Car_Function_Adaptations_Gen2-menu_display_oil_level change to active
(93)-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high change to active
(3)-Car_Function_List_CAN_Gen2-Oil_level change to available
(4)-Car_Function_List_CAN_Gen2-Oil_level data bus...change to Terminal 15
enable then do a reset, they'll appear in your unit is ready to.
unit 17
long coding
byte 15 bit 4
>>>>>Under testing<<<<< You can test it but I can't guarantee they work like the other above
HBA for MY17 at the moment the coding is for OBD11 but even with vcds the unit 9 is in German
OBD11
unit 09
Adaptations:
Erweiterte_Fernlichtsteuerung change to AFS, FLA, Fernlicht ueber AFS (full beam assistant)
Menuesteuerung Fernlichtassistent change to Present (full beam assistant menu)
Module A5:
Long coding: byte 2 enable bit 01
VCDS
unit 9
I need a unit 9 adaption list of a MY17 to add the missing adaption!
(2)-Assistance light functions-Menuesteuerung Fernlichtassistent change to present
Module A5:
-sensibility of the light sensor
Unit 9
(12)-Assistance light functions-Lichtsensorempfindlichkeit,normal
the option are sensible, less sensible, normal
-Rear dynamic indicators
here the electric part on the rear light side, I need someone that can disconnect the rear light and take picture of the connector male and female side
non dynamic led
1 brown
2 blue white
3 blue
4 blue yellow
5 red black
6 yellow blue
dynamic led
1 brown
2 blue white
3 blue
4 blue yellow
5 red black
6 yellow blue
7 grey white
8 not used
as you can see, dynamic leds use an 8 pin connector...if the connector is already an 8 pin, you can add a wire for try and you could get dynamic led..but you should buy new lights!
the pin 7 has to be connected to the unit on the left of the light switch at pin T46/22
I'll provide further details if needed
#2,547 ·
Unit 5F
Coding
Unit 5F
Adaptions
Unit 03
Adaptations
default is medium
Unit 9
Adaptions
find in the menu
change the value to
Unit 10
Coding
Byte 3
Disable bit 4
Unit 5
coding
byte 2
Adaption
Unit 17
adaption
find in the menu:
Unit 5F
adaption
find in the menu
Unit 9
adaption
Unit 9
Adaption
Unit 5F
Adaption
find in the menu:
Unit 19
Adaptation
Unit 5F
adaption
unit 17
long coding
byte 15 bit 4
OBD11
unit 09
Adaptations:
Module A5:
VCDS
unit 9
Module A5:
Unit 9
non dynamic led
1 brown
2 blue white
3 blue
4 blue yellow
5 red black
6 yellow blue
dynamic led
1 brown
2 blue white
3 blue
4 blue yellow
5 red black
6 yellow blue
7 grey white
8 not used
please send me password for HBA my 16 pdf attachament
ManuTT said:
if the thread takes go, I actually have these codes:
-show the needles when we turn on the car and the cockpit shows the odometer and the rev
-turn down the right mirror when we use the reverse
-activate the speed signs recognitions
-deactivate the fasten belt sound and symbol
-set the exhaust valve always full open and not open after a number of revs (like in the TTs)
-set on/off and how much light for the rear daytime running lights
Please do it ! :lol: :lol:
Could you put the code up for activate the speed signs recognitions. This would be great if you could? also any news if you can have the front dynamic indicaters too?
I have these set on the car a while ago but there are some that just dont work:
- Enable Lap timer but cant see it anywhere in Menu ? (I did the same with my wife's car Q5 and can see in the Car Menu)
- Traffic sign recognise : the Adaptation (63) "vehicle function list" -> "BAP traffic_sign_recognition_0x21" : when I set it to Active it accept the change but it actually still shows Not active somehow. Other Options set Active alright. No sure why.
- Disable Exhaust Flap : In my car that option is untick (Exhaust Flap Installed) but the sound is not as loud as I want in D mode. Is there a setting that to make it as loud as S mode but in D mode ? (to avoid using GearBox in Dynamic mode)
Lap timer I didn't try because I don't have the need so I'm
Sorry about that..
About the traffic signs, I've wrote that some option could remain non active but the storm works anyway..did you activate it or you've tried but it doesn't work? If so, I'll post another guide
The flap coding is useless because you can set the exhaust open in individual mode..
Sorry about that..
No sorry needed mate.... I actually did these codes a long time ago though, back to the day I bought the car in April but there isn't much info for this too new model.
Now it may be a fun time ahead with more joining the club :D
ManuTT said:
The manual says to check on audi.com the countries where traffic recognitions works but I didn't find that list..
Isn't anyone here around you to double check?
Unfortunately I dont think so. Driving a fair bit last couple of months but I saw just another one on the road. The rest are MK2
#21 ·
-Enable auto handbrake when shift in P (my cable can't have access at this unit, so not tested)
Unit 53
Security access, code 78713
Adaption
Find "shift p to epb"
Activate it and done.
-Release automatically parking brake without seat belt (my cable can't have access at this unit, so not tested)
Unit 53
Adaption, find the function and activate it
-I hope soon, activate high beam assist
-dynamic front indicators, I need your help to research...check in the unit 9 if you have all parameters activated like mine:
(1)-Dyn. turn signal modes-Schluessel_Anlern_Blinken, active
(2)-Dyn. turn signal modes-UGDO_ Anlern_Blinken, active
(3)-Dyn. turn signal modes-ZV_Blinken_zu, active
(4)-Dyn. turn signal modes-ZV_Blinken_auf, active
(5)-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken, active
(6)-Dyn. turn signal modes-DWA_Schaerfungsquittung, active
(7)-Dyn. turn signal modes-DWA_Alarm_Blinken, active
(8)-Dyn. turn signal modes-Taxi alarm flashing, active
(9)-Dyn. turn signal modes-Panic flashing, active
(10)-Dyn. turn signal modes-Multi_kollisions_Blinken, not active
(11)-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2, not active
(12)-Dyn. turn signal modes-Richtungs_blinken_rechts, active
(13)-Dyn. turn signal modes-Richtungs_blinken_links, active
(14)-Dyn. turn signal modes-ABBA_Blinken, active
(15)-Dyn. turn signal modes-Crash flashing, not active
(16)-Dyn. turn signal modes-Warnblinken_Zuendung_EIN, active
(17)-Dyn. turn signal modes-Warnblinken_Zuendung_AUS, active
(18)-Dyn. turn signal modes-Emergency_alert_blinken, not active
