Spacer Spacer
  • Start
  • News
  • Forum
  • Advertise
  • TTOC
  • Search
  • About TTF
Board index   FAQ   Search   Garage   Gallery
Register  Login
Board index ‹ UK TT Forum ‹ TT Forum - MK2 TT (8J)
Quattro front tyre replacement
Discuss all things to do with the MK2 TT 8J (2006-Present)
Moderators: John-H, Ikon66, T3RBO, DXN, Hoggy
Post a reply
5 posts • Page 1 of 1
jophenna
  • jophenna's Profile
TT Forum Member
TT Forum Member
PostPosted: 15 Mar 2010, 23:02
Hi all,
My v6 is going for it's first mot tomorrow and I know that the front two tyres are very low so I need to replace them. I have heard in the past that on 4wd vehicles you need to replace all 4 tyres together but after a bit of research now believe that I'm ok to change both fronts.
I'm currently running on stock Michelin pilots. 245/40zr18. National tyres have offered a pair of pilots for 580 fitted or a pair of bridgestones for 380. Can I get away with going for the cheaper bridgestones or do I have to go for michelins?
Many thanks for your help!!
Advertisement
Tim G
  • Tim G's Profile
User avatar
Too Much Time On My Hands
2002 Audi TT MK1 - 1.8T (quattro)
PostPosted: 15 Mar 2010, 23:07
Buy the Pilots from somewhere that wont rip you off and you wont need to worry :roll: :P For example
http://www.camskill.co.uk/products.php? ... s323p58281
jophenna
TT Forum Member
TT Forum Member
PostPosted: 16 Mar 2010, 06:43
Thanks for your response.
The problem I have is that my mot was due on Saturday and I only found out yesterday... so I have no option but to buy new tyres locally this morning as my mot is this afternoon and I know the car will fail on the two front tyres.
Those are my only two options... I'd prefer to buy the Bridgestones, so long as they aren't going to cause any trouble with the drivetrain...
Anybody know if this is likely to cause any problems down the line?
Cheers!
sTTranger
  • sTTranger's Profile
2010 Audi TT MK2 - TTRS
PostPosted: 16 Mar 2010, 08:41
only need to replace 2 tyres, best to have the same tyres on each axel. What have you got on at the moment??
jophenna
TT Forum Member
TT Forum Member
PostPosted: 16 Mar 2010, 09:08
Cheers for the response.
I checked the tread on the rears this morning and found that they are just 3mm... so decided to replace the four. I have done a bit of looking around and found that KwikFit could do the four for 775 with a £25 petrol voucher! Cheapest I could find anywhere.
Booked in for fitting on Thursday... so got to hope and pray that the MoT centre pass the fronts which are currently at 1.6 and 1.8mm. I'm in the belief that at 1.6mm it should pass as they are not yet technically illegal..? After all you can't get prosecuted for doing 30mph in a 30 zone can you... or am I being naive here?
Post a reply
Return to TT Forum - MK2 TT (8J)
Who is online
Registered users: Bahamuri, bigbison, Bing [Bot], Callum-TT, carlviper, CRU57Y, dewman, gcp, Google [Bot], Google Adsense [Bot], Google Feedfetcher, gulfer85, jakekk, John-H, MRj, Nem, PTP400, Real Thing, Sean-f, Shootist, timothy2309, TondyTT, TTSPORT666, Wak, whanab
  • Board index
  • The team • Delete all board cookies • All times are UTC
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
© 2000 - 2010 All Rights Reserved, TTForum Style designed & coded by Christian Bullock
