Status
Not open for further replies.
FAQ - Audi TT Mk2 (8J) Excessive Oil Consumption
14K views 1 reply 1 participant last post by  SwissJetPilot
#1 · (Edited by Moderator)
Engine oil consumption has been a serious problem for some of Audi's 2.0 engines, especially those produced prior to 2012. Generally speaking, blue smoke out of the exhaust is typical of oil getting past the rings or valve guides.
Audi published a Technical Service Bulletin (TSB) revision regarding this issue back on August 2012 which covered several Audi models including the MK1 and Mk2 TT from 2000 - 2013. You can download it here -
https://www.ttforum.co.uk/attachmen...achments/engine-oil-consumption-measurement-repair-authorization-ca-pdf.387395/
A leakdown test measures how well the cylinder is sealing. This is done by inserting compressed air (around 100 psi) into the cylinder at TDC and then measuring how much is lost from the seals (there will always be some). This is done by two gauges on the leakdown tester—see the article below.
As with the compression test, you want the numbers to be within a percentage of each other. The leakdown test can also help you pinpoint the problem before tearing down the motor by listening for the air escaping the cylinder. Once the cylinder is pumped up, listen for air escaping from the cylinder and where the sound is coming from.
The original article can be found here -
Audi 2.0 TFSI Engine Oil Consumption – Correction
What is the problem?
The early version of the TFSI gasoline engines found in the A5, A4 and Q5 have an inherent design fault which leads to high consumption of oil.
The base problem seems to relate to the piston rings, which allow small amounts of oil to leak round the pistons into the cylinders, where it burns and therefore leads to high oil consumption. The typical way drivers become aware of this is when the ‘add one litre of oil’ notice comes up on the dashboard. When this comes up you don’t need to immediately stop, but you should add a litre of correct grade oil as promptly as you can.
Over time this problem gets worse, and the range you can drive before needing to add oil steadily drops. In advanced cases there can be noticeable smoke from the exhaust under heavy acceleration, and it is also known to damage the actual cylinders themselves, causing scoring in the bores. One theory is that these grooves cause more and more oil to leak around the pistons, hence the problem gets progressively worse.
Note that the Audi specification for the 2.0 engines allows for a quart of oil to be used every 1,000 miles, and they will not consider this level of usage to be a fault. This is written in the manual if you look in the section on oil. However, many 2.0 TFSI owners routinely get only around 500-600 miles, which is definitely out of spec. (Other engines may have different specifications, please check your manual to confirm)
What engines are affected?
The 2.0 and 1.8 TFSI engines prior to 2012. Engine codes known to be affected include CAEB, CDNC and CNDC (list being updated). The problem seems to have been corrected when the facelift was released. But all A5 TFSI engines before that, i.e. 2008 – 2012, are susceptible.
The overwhelming majority of reports are for the 2.0, but 1.8 TFSI is also affected. There have been far fewer reports from 1.8 owners and information is harder to find. It is unclear whether this is because the 1.8 is less susceptible to the problem, or there are simply less 1.8 engines in existence.
Diesels engines are not affected, but there have been isolated reports of the larger petrol engines such as those found in the S5 also having an oil problem, but it’s unclear if this is the same issue. Again, S5’s are far less common than 2.0 TFSI A5s, so that may be the reason there are few reports of this.
The following advice should be generally applicable for any owner with oil problems, but is primarily based on the experience of 2.0 owners. If you have a different engine and find information that contradicts this FAQ, please post below and I will update.
How can I tell if I have the problem?
It’s fairly easy to test. Top up your oil then reset your odometer. When the one litre message comes up if you’ve done less than 1200 miles you have the problem. In practise if you are getting anything under 2000 miles you probably have the problem, but Audi won’t acknowledge it until you get below 1200 miles. (this is correct for 2.0 engines, I am not sure the spec mileage for other engines)
However, for Audi to do any corrective work you need to have an official consumption test done by a main dealer. For this they will drain your car of oil, then fill it up with a carefully measured volume so they know exactly how much is in the engine. You are then asked to drive 500 miles, or until the one litre warning comes on, whichever is first. At that point you return to the dealer, they drain the engine again and carefully measure how much is left. In this way they can get an extremely accurate measurement of the oil used over the distance. If more than half a quart has been used over 500 miles, the car has failed the test and they will recommend a repair. It is essential that you not top up the oil during the consumption test, as it will invalidate the result.
Audi dealers will typically charge $80-125 for the consumption test, although this is sometimes waived for goodwill.
Can I ignore it?
For a long time, especially when Audi wasn’t offering much in the way of financial contribution, many TFSI owners took the view that it wasn’t harming the engine, and buying a 4 quart bottle of oil every few months was a lot cheaper than the repair.
However, it has now been confirmed that the problem does harm the engine, it causes scoring and grooves to be worn into the cylinder bores. In the short term these make the problem worse, longer term this could eventually cause the engine to fail.
So you are strongly advised not to just ignore the issue.
Can it be fixed?
There are three known solutions offered by Audi.
Stage 1
This involves replacing the crank case and updating the engine management software to the latest release. While it appears to reduce the problem in some cases, and is sometimes offered alongside the consumption test as an initial fix, it does not seem to be a permanent solution and Audi does not seem to be offering it very often anymore. Audi dealers typically charge $200 for this but it is sometimes offered free with the test as goodwill.
Stage 2
This involves removing the engine from the car, stripping it down to the cylinders and replacing the pistons, piston rings and con rods. It takes around 12 hours to do this, so it is not a trivial piece of work. Provided there is no other damage the stage 2 solution will completely fix the problem. Audi dealers typically charge $5,000 – $6,00 for this.
However, before conducting a stage 2 fix, the dealer should check the cylinders to see if they have been damaged. This is done either by stripping the engine, or by putting an endoscope in through the spark plug sockets. If the bores are damaged the stage 2 fix is not suitable as the grooves will still cause oil to leak around the rings.
Stage 3
The final repair option is a completely new or good quality used engine, and this is the only fix that will work if the cylinders have been damaged. This is a permanent fix, the replacement engine will not have the same problem. Audi dealers typically charge $12,000 – $14,000 for a new engine this.
Note that both the Stage 2 and 3 are permanent solutions, neither is more effective than the other, and there is no requirement to have the stage 2 before you have the stage 3, in fact that would only happen if the dealer missed there being engine damage in the cylinders.
The only thing that decides whether you need the stage 2 or 3 is the presence of scoring damage in the cylinders.
Other solutions.
Some drivers have reported that using different grades of oil, or engine treatments such as STP, can improve the problem. But while there might be some small incremental improvement, there is no evidence that they significantly reduce the problem or provide a fix. Crucially, Audi doesn’t seem to have ever recommended these solutions, and given how expensive the other options are it seems likely they would have at least tried it if there was any chance it might work.
What are Audi doing about this?
For a long time Audi dealers were quite reluctant to admit there was any problem, and while they did provide the various fixes listed above, unless the car was still in warranty the owners were typically requested to make a significant contribution to the cost, sometimes to the tune of several thousand pounds. After market warranties also didn’t seem to cover the issue as it was either categorised as a manufacturer defect or else wear and tear. This left many owners facing having to live with the problem due to the huge expense of rectifying it.
However, in 2014 a class action lawsuit was brought against Audi in America, and while they have not formally admitted liability, they have made a settlement offer to American owners. This extends the manufacturers engine warranty to 8 years or 80,000 miles, and will fully cover the cost of the required repairs up to and including a new engine. American TFSI owners should read this website to find out details of this and how they can claim.
Apparently as a result of this finding in America, as of 2015 Audi in other countries appears to have had a change of heart and are now making 100% contributions to remedial work for affected cars that meet their criteria. In March 2015 I personally had the stage 3 fix, i.e. a whole new engine, provided completely free of charge despite my car being two years outside of its manufacturer’s warranty.
In June 2015 Audi UK made the following statement in response to an article on BBC Watchdog about the problem. It essentially confirms that they are contributing, but that certain service criteria need to be met. (original statement here https://www.audi.co.uk/about-audi/la…june-2015.html )
Quote:
Audi UK is committed to investigating and swiftly resolving any technical issues relating to our cars which are reported to us through our network.
As we have stated previously, a low percentage of older 2.0 TFSI engines fitted to certain models have been exceeding the factory oil consumption tolerance of 0.5 litres per 1,000 kilometres (approx. 620 miles). Changes were made to the production tolerances of the pistons and rings in this engine from mid-2011 onwards, and customers with 2.0 TFSI cars produced after this date should not have any cause for concern.
The comprehensive Audi UK Warranty (3 years/60,000 miles) covering all new Audi vehicles has already resolved the majority of these cases at no cost to the customer. For remaining affected customers with cars that are no longer covered by this warranty, we have a policy in place to resolve issues on a case-by-case basis. This revised policy has been in force nationally since the beginning of the year and applies to new and retrospective cases.
Qualification criteria are applied in each individual case to confirm that the vehicle has been serviced in accordance with the owner’s handbook by an Audi Centre or other professional workshop which follows the Audi Service quality standards.
We invite all Audi customers who have any questions or concerns relating to newly discovered or previously reported oil consumption with 2.0 TFSI engines to contact their local Audi Centre. Alternatively, our advisors will be available until 10pm on Thursday 4 June, and thereafter from 8am to 8pm, by calling 0800 093 0110 free of charge from landlines*.
*Chargeable from mobile phones.
What are the criteria for getting the fix for free?
There appear to be two main criteria.
1. You have a full Audi Service History
2. You engine has not been in any way modified, e.g. a performance remap or any other after market modification
If you have a less than perfect service history, Audi may reduce their contribution and you will need to make up the difference. However, there is some evidence that if you can produce garage receipts showing that the correct grade of oil was used, this may mitigate against this. The relevant line in the Audi press statement is “the vehicle has been serviced in accordance with the owner’s handbook by an AudiCentre or other professional workshop which follows the Audi Service quality standards.”, so if you have used an independent garage you may need to provide evidence that they followed Audi standards.
An engine remap or similar after market modification will likely cause Audi to refuse all contribution and it will be difficult to argue against this. It’s likely to be hard work though and there are obviously no guarantees.
Another unofficial factor appears to be the particular dealer you go to. It seems that Audi expect the dealers to contribute to the cost as well, and some dealers seem more willing to undertake the work than others. Your personal history with the dealer may also help here, if you have had several services and other work done by the main dealer, they are more likely to help. But if you turn up with a problem car and it’s the first time you’ve ever spoken to them, you may have a harder time.
I have an affected car and I’m pretty sure it’s out of spec, what should I do?
If you are in the US, read the class action page linked here.
Oil Consumption Settlement > mainpage > Home
In other countries, take it to your local dealer and say you have an oil consumption problem and would like them to look at it. BE POLITE, it is the dealer who will apply to Audi on your behalf for the contribution, so you want them on your side. If you go in demanding your rights, quoting law suits and generally being a pain, like any other human they are less likely to go the extra mile working on your behalf with Audi. You can always bang the table later on if the contribution isn’t what you want. I asked very politely and their opening offer to me was a completely free replacement engine without any negotiation required at all.
If the dealer doesn’t cooperate, either consider another dealer or else speak to Audi direct. You may want to ask in this thread for a recommendation of a helpful dealer or who to speak to at Audi. However, the issue is getting more and more profile and publicity, having been featured in the UK national press, and more recently on the BBC Watchdog consumer affairs program. This should lead to more and more dealers following the Audi line and fixing the problem.
I already had my car fixed a year or so ago, and paid a hefty contribution
Some owners who previously paid large contributions towards a fix are now understandably upset that work they paid for is now being provided free. When this issue was featured on Watchdog, four owners were shown who had previously made contributions, and as part of their response to the article Audi agreed to refund all four of them. So if you previously paid to have this problem fix, you should politely go and speak to the dealer who did the work, quoting other examples of owners who have had the same work fixed for free. It would appear there is a very good chance you will be issued a refund.
I am thinking of buying a pre-2012 Petrol TFSI car and heard about this issue, what should I do?
Many owners who realised they had this problem but didn’t know or believe that Audi would fix it have part exchanged their car to be rid of it, so there is likely to be quite a large number of affected cars in the used market. If you are considering buying any pre-2012 car with this engine for your own sake you should work on the assumption that it has the problem and it is likely to get worse. Bear in mind that even on badly affected cars you have to drive several hundred miles to be able to diagnose the issue, so dealers who have taken these cars in part exchange could well be completely oblivious to it and you can’t rely on any dealer assurances. Although a written assurance would be useful if you later want to make a claim.
However, that doesn’t necessarily mean you shouldn’t buy the car, and in fact you might be able to get quite a bargain as a result. But keep the following in mind.
1. Don’t touch any example that doesn’t have a full Audi Service History, or at least negotiate a very serious discount, e.g. $4k to cover the potential contribution
2. Don’t touch any car that you think might have been remapped or modified
3. Even if the car appears to be on the level , be aware that you might have to go through several months of hassle to get the problem resolved, and as with any used purchase there is always the risk that something will crop up (e.g. a remap or dodgy service) that leaves you needing to make a contribution. Use the normal rules of used purchase to minimise this risk, i.e. a dealer is safer, an Audi dealer safer still, and if its a private sale then buyer beware!.
If you are at all in doubt, or just don’t want the hassle, walk away from any car with this engine. Either go for a diesel, or wait a year or so until the Facelift models come down to your price point. Don’t risk getting stuck with a dying engine that Audi won’t touch and you can’t afford to fix.
- Thanks to the Atlantic Motorcar Center for this article and images.
How to do an Engine Leakdown Test
How to do an engine leakdown test
Difficulty: Moderate
Estimated time: 120 minutes
An internal combustion engine makes power by first drawing air and fuel into the combustion chamber. Next is the compression of the mixture and the addition of a spark. The harnessing of the resulting contained explosion is ultimately what powers the car. As an engine gets on in miles, the containment of this power can be lost due to piston ring, valve or cylinder wall wear. Engine performance will suffer as a result.
Pressure reading
A common test of an engine’s ability to compress the air-fuel mixture is an engine compression test. A pressure gauge is connected in place of the spark plug. The engine is then cranked to create a pressure reading. A compression test is a good way to check the engine’s ability to create pressure. The gauge reads the positive pressure created by the cylinder.
Loss reading
An engine leakdown test is a compression test in reverse. Instead of measuring the engine’s ability to create pressure, compressed air is introduced into the cylinder through the spark plug hole. One gauge on the tester measures the pressure of the air entering the cylinder and the other measures the percentage of the air escaping (or leaking) from the cylinder. The loss percentage will indicate the condition of the cylinder and overall condition of the engine.
Top dead center
Before sending air into the engine, the cylinder being tested must be placed at Top Dead Center (TDC). The piston must be at the top of its travel. The intake and exhaust valves must be closed. When the air is compressed into the cylinder, the leakdown tester will measure any loss of air escaping past valves or piston rings. If the cylinder is not at TDC, air escaping past an open valve will give a false reading.
Reading results
No engine will have perfect sealing with 0 percent loss. Five to 10 percent loss indicates an engine in great to good running order. An engine between 10 and 20 percent can still run OK, but it’ll be time to keep an eye (or ear) on things. Above 20 percent loss and it may be time for a tear down and rebuild. Thirty percent? Major problems. The percent of leakage should also be consistent across the cylinders. Any great differences indicate a problem in that cylinder.
Hearing problems
Beyond getting an overall picture of engine condition, the engine leakdown test is an excellent way to pinpoint where problems are before tearing down the engine. Listening for where the air is escaping by ear can isolate the problem.
  • Intake valve : Air whistling out of the intake, carburetor or throttle body indicates a leak at the intake valve.
  • Exhaust valve : Air heard hissing out of the tailpipe, turbocharger or exhaust manifold means an exhaust valve leak.
  • Piston rings : Whistling or hissing out of the PCV valve, oil filler cap hole or dipstick tube means the air is pushing past the rings. Suspect ring or cylinder wall wear.
  • Head gasket : Air bubbles in engine coolant seen at the radiator filler cap could mean air escaping into the coolant past the head gasket.
  • Cracked cylinder head : Bubbles in coolant or coolant being pushed up out of the radiator neck can also indicate cracks in the cylinder head or cylinder walls.
Tools, supplies and instructions
You will need a compressed air source, a leakdown gauge kit, spark plug socket, basic hand tools, vehicle service manual and a notepad to record results.
Remove spark plugs and rotate engine
Step 1 : Remove the spark plugs and rotate the engine to put the cylinder to be tested at TDC. Tip: Insert a long screwdriver or extension into the spark plug hole and turn the engine by hand with a socket on the crankshaft. When the screwdriver stops rising or falling, you’re at TDC. Don’t turn the engine backward if TDC is missed. Go around again. In a four-cylinder engine, cylinders one and four and two and three are at TDC at the same time.
Pressurize air into the cylinder
Step 2 : Figure out which spark plug adapter works best and connect the gauge into the hole. Put the vehicle in gear and set the parking brake to prevent the engine from turning when air is compressed into the cylinder. Start with the regulator turned counterclockwise to zero the incoming pressure. Connect compressed air. Turn the regulator clockwise to pressurize air into the cylinder.
Engine leakdown percentage for the cylinder
Step 3 : Record leakage percentage for the cylinder. Remove the oil dipstick, radiator cap and oil filler cap. Open the throttle body or remove the air cleaner. Listen and watch. Wherever air is escaping will indicate where the problem is. Disconnect the gauge and move to the next cylinder.
Thanks to Mike Bumbeck at automedia.com for this article and images.
Status
