Moderators: John-H, DXN, Ikon66, T3RBO, Hoggy
Hi everyone,
Please could someone point me in the right direction on some of these codes, etc from VCDS: Car: 1.8t ARY Address 01: Engine Labels: Redir Fail! <<< ? Controller: 8N0 906 018 AQ Component: 1.8L R4/5VT 0001 Coding: 10710 Shop #: WSC 01236 VCID: 80738303931B 3 Faults Found: 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation <<< Changed this already. P1340 - 35-10 - - - Intermittent 16795 - Secondary Air Injection System: Incorrect Flow Detected <<< Going to dril the rivets out and blot because it squeals on startup. P0411 - 35-10 - - - Intermittent 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 35-10 - - - Intermittent Readiness: 0000 1101 Address 03: ABS Brakes Labels: None Controller: 8N0 907 379 H Component: ESP ALLRAD MK60 0101 Coding: 0022549 Shop #: WSC 01236 VCID: 41F5C6075891 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Address 17: Instruments Labels: 8Nx-920-xxx-17.LBL Controller: 8N2 920 950 Component: KOMBI+WEGFAHRS. M73 D02 Coding: 05444 Shop #: WSC 00000 VCID: F195D6C7A8B1 2 Faults Found: 01314 - Engine Control Module 49-10 - No Communications - Intermittent 01336 - Data Bus for Comfort System 37-10 - Faulty - Intermittent Address 22: AWD Labels: 02D-900-554.LBL Controller: 02D 900 554 C Component: HALDEX LSC ECC 0010 VCID: 20336383B3DB 1 Fault Found: 01314 - Engine Control Module 49-00 - No Communications Address 35: Centr. Locks Labels: 8Nx-962-267.LBL Controller: 8N8 962 267 C Component: Zentralverrieg.,DWA D06 Coding: 06826 Shop #: WSC 00767 VCID: 41F5C6075891 1 Fault Found: 01134 - Alarm Horn (H12) <<< Going to pull the siren out and check the batteries. 49-00 - No Communications Recently replaced: MAF, N75 & DV. Any help anyone can give is greatly appreciated. Audi TT 1.8T Quattro ARY 02
Did you clear errors, before doing this scan, or is the above the first scan?
If you didn't clear all errors, then rescan, do that now. Some of those errors may well be historical,and not current. Mac. |
When was your timing belt last changed, being out a tooth can lead to incorrect correlation errors
Hey Mac, Yeah I did clear them mate and have cleared them againand going to retest again in a few days. Would having the ignition on only for a good while and messing with VCDS cause the no communications errors becuase Ive not had them before. Audi TT 1.8T Quattro ARY 02
Hi StuartDB, Well... I have read this somewhere already, maybe on here. I've only had the car since August last year (only for work purposes) and within the paperwork, I cannot see any indication that its been changed. I recently did a full service myself and the oil was bloody aweful. I've checked the belt and it looks to be in OK condition but I am going to change it. The cars just hitting 90k now so it's quite concerning I suppose if it hasnt been done already. Audi TT 1.8T Quattro ARY 02
I think you are on borrowed time Sir. If PO didn't change the oil, they certainly wouldn't have changed cam belt, pump, tensioner etc. Mac |
Yeah I know mate, going to get it done asap. Where would be the best place to by everything I need from? EuroCarParts? Audi TT 1.8T Quattro ARY 02
While you are doing some spannering i would get the sump off and do the strainer and clean out the sump,this 1 is good for piece of mind for what it costs
Cheers Jester, will do that mate. Audi TT 1.8T Quattro ARY 02
my point was more that if you changed it last week it might have been put on a tooth out - I did this on 2 out of 3 timing belt changes - the car drives okay you just get an EML every few days. but if your oil is really poor it may not be correctly adjusting the VVT which adjusts the cams |
Yeah thanks mate, I've read this quite a lot on here. Audi TT 1.8T Quattro ARY 02
Return to TT Forum - MK1 TT (8N)
Registered users: -:[KM]:-, 47yellow, 8JVR6, AJP, Akafreakazoid, Andash, Andywill, auspicious_character, bathchoppers, benckj, benslingsby, Bing [Bot], bryanmccrae, Budgie-TT, Calibos, CaptRon, cb550, classexa, Danbtt, darylw357, davebowk, David C, Deepreddave, desertstorm, Donovan2123, droopsnoot, DST, FJ1000, Gareth Crossland, giusemanuel, Google [Bot], Google Adsense [Bot], Hadaak, hakanbeyci, Hoggy, ibuckley, Ikon66, imartyn, InkyUK, jaydee77, jlloyd1, John-H, kartstuffer, kato, kevin#34, Kievebuh14, Kky, Knight-tts, Llewkcalb, MarksBlackTT, mostly, Nidana, Nipun, noidea, NP46, QCOUPETT, S11HHU, seTT, SharonsBaby, simon3868, Smokehead, Stav, Steve2017TTS, STT3, surfer8210, SwissJetPilot, Tebor123, timandrew, Timmybizzle, titch3030, TT22, tt92103, TTJDP, TTpiloti, TTRoper, Vassilis, Wolfie7
ttforum.co.uk is an independent Audi enthusiast website owned and operated by VerticalScope Inc. Content on ttforum.co.uk is generated by its users. ttforum.co.uk is not in any way affiliated with Audi AG |
