Hi all, various searches concluded that this was the best TT forum to join for information advice etc.
Used my daily runner a few times on track but decided better to get a dedicated track car and it had to be something VAG.
The MK1 225 TT offers a lot of car for not so much money really. Problem is trying to find one thats not had a million owners and been to the moon and back.
After looking for a few weeks came across this Y plate example with 88K on the clock and 5 previous owners. Full service history and a recent cam belt/ water pump change.Its totally standard in pretty much every way, I cannot find any mods or tweaks, still has the original diverter valve and stock air box etc. Even has the original untouched first aid kit.
Fixed some of the issues that the car had, micro switches in the door locks both sides, dismantled the G200 sensor and resoldered the chip, replaced the rear brake discs and pads and the one caliper as the piston was seized.
Plans are for a full strip, if it doesn't need to be there to make the car run/stop it will be going.
Brembo LCR calipers with 330mm discs, ds300 pads. Half cage , bucket seats , probably Gaz Gold suspension with the various suspension tweaks / bushes etc needed. Haldex insert.
Welly cooler and a tip with a divertor valve and a remap by Rick at Unicorn Motor developments.
plus loads of other stuff I am sure.
Want to get the car up and running and trackable with suspension , brake , interior mods and mild tweaks to the engine.
Longer term looking to replace the turbo and fit rods etc in the engine as well as oil cooler / exhaust etc for something a bit more serious.
Hopefully I can get it as quick as my daily driver diesel estate .
Index to the thread, Links to various mods in the thread.
Air con delete https://www.ttforum.co.uk/forum/viewtop ... 9#p8098729
Seat Leon Cupra R brakes https://www.ttforum.co.uk/forum/viewtop ... 7#p8098777
Cookbots https://www.ttforum.co.uk/forum/viewtop ... 7#p8104497
EGT Sensor fix https://www.ttforum.co.uk/forum/viewtop ... 2#p8176722
Intercooler testing and install https://www.ttforum.co.uk/forum/viewtop ... 4#p8290274
Badger 5 TIP https://www.ttforum.co.uk/forum/viewtop ... 6#p8290306
3 inch down pipe and cat delete https://www.ttforum.co.uk/forum/viewtop ... 8#p8290378
Boost gauge https://www.ttforum.co.uk/forum/viewtop ... 4#p8293154
Remap at Unicorn Motor developments https://www.ttforum.co.uk/forum/viewtop ... 6#p8301546
oil cooler https://www.ttforum.co.uk/forum/viewtop ... 0#p8352170
Gaz Gold suspension https://www.ttforum.co.uk/forum/viewtop ... 9#p8370249
Seats https://www.ttforum.co.uk/forum/viewtop ... 8#p8389258
Decat pipe https://www.ttforum.co.uk/forum/viewtop ... 6#p8430786
Team Dynamics Jade alloys https://www.ttforum.co.uk/forum/viewtop ... 8#p8438058
Rear weight removal https://www.ttforum.co.uk/forum/viewtop ... 2#p8465522
Haldex powertrak insert https://www.ttforum.co.uk/forum/viewtop ... 4#p8472034
Shift light https://www.ttforum.co.uk/forum/viewtop ... 2#p8480762
Brake cooling ducts https://www.ttforum.co.uk/forum/viewtop ... 8#p8495258
Gearbox oil change https://www.ttforum.co.uk/forum/viewtop ... 9#p8512369
Rocker cover oil leak https://www.ttforum.co.uk/forum/viewtop ... 6#p8515546
MK 2 Bottom balljoint upgrade https://www.ttforum.co.uk/forum/viewtop ... 3#p8520673
Low fuel pressure testing https://www.ttforum.co.uk/forum/viewtop ... 5#p8595625
Hunter car alignment https://www.ttforum.co.uk/forum/viewtop ... 4#p8602514
Roll cage https://www.ttforum.co.uk/forum/viewtop ... 2#p8628762
Forge baffled sump https://www.ttforum.co.uk/forum/viewtop ... 2#p8631922
DAB radio Handsfree install https://www.ttforum.co.uk/forum/viewtop ... 5#p8633145
Cage install and sound desdening removal https://www.ttforum.co.uk/forum/viewtop ... 2#p8689762
AC evaporator and wiring removal https://www.ttforum.co.uk/forum/viewtop ... 0#p8730490
Battery install https://www.ttforum.co.uk/forum/viewtop ... 3#p8735273
Battery Install 2 https://www.ttforum.co.uk/forum/viewtop ... 8#p8757658
OMP steering wheel https://www.ttforum.co.uk/forum/viewtop ... 9#p8748849
Short throw gear change https://www.ttforum.co.uk/forum/viewtop ... 5#p8795025
Alarm battery replacement https://www.ttforum.co.uk/forum/viewtop ... 2#p8801402
DW65V fuel pump install https://www.ttforum.co.uk/forum/viewtop ... 6#p8818146
Catch can https://www.ttforum.co.uk/forum/viewtop ... 4#p8845074
Ebay rear wing https://www.ttforum.co.uk/forum/viewtop ... 4#p8854354
RS3/TTRS front brake upgrade https://www.ttforum.co.uk/forum/viewtop ... 4#p8871074
Rear towing eye https://www.ttforum.co.uk/forum/viewtop ... 0#p8978690
Rear brake upgrade https://www.ttforum.co.uk/forum/viewtop ... 2#p8983402
Vortex generators https://www.ttforum.co.uk/forum/viewtop ... 1#p8986271
Rear brake pipe repair https://www.ttforum.co.uk/forum/viewtop ... 9#p8988349
Custom exhaust at Longlife https://www.ttforum.co.uk/forum/viewtop ... 7#p8990027
Curbrough June 2018 https://www.ttforum.co.uk/forum/viewtop ... 9#p8993349
Rockingham June 2018 https://www.ttforum.co.uk/forum/viewtop ... 1#p8995051
V6 radiator upgrade https://www.ttforum.co.uk/forum/viewtop ... 1#p8999061
Autec Wizard allo wheels https://www.ttforum.co.uk/forum/viewtop ... 1#p9005741
Car weigh in at Track toys https://www.ttforum.co.uk/forum/viewtop ... 7#p9015747
VAG Tuner live Donnington July 2018 https://www.ttforum.co.uk/forum/viewtop ... 5#p9015815
Corner weighting at Track Toys https://www.ttforum.co.uk/forum/viewtop ... 5#p9040045
Curbrough August 2018 https://www.ttforum.co.uk/forum/viewtop ... 1#p9043641
G25-660 arrives https://www.ttforum.co.uk/forum/viewtop ... 7#p9052867
Intake manifold TB adaptor plate https://www.ttforum.co.uk/forum/viewtop ... 3#p9073413
Donnington October 2018 with Dad https://www.ttforum.co.uk/forum/viewtop ... 1#p9074951
Bi XENON headlight modification https://www.ttforum.co.uk/forum/viewtop ... 1#p9075421
Nortech manifold and Downpipe https://www.ttforum.co.uk/forum/viewtop ... 1#p9076291
Lightweight 70A alternator https://www.ttforum.co.uk/forum/viewtop ... 1#p9079551
MAP sensor mounted on intake manifold https://www.ttforum.co.uk/forum/viewtop ... 1#p9089051
PLX AFR gauge install https://www.ttforum.co.uk/forum/viewtop ... 9#p9090739
Ignitron ECU install https://www.ttforum.co.uk/forum/viewtop ... 1#p9092111
Engine out for first rebuild https://www.ttforum.co.uk/forum/viewtop ... 3#p9101983
Engine going back in the car https://www.ttforum.co.uk/forum/viewtop ... 7#p9140177
8600 RPM https://www.ttforum.co.uk/forum/viewtop ... 1#p9153041
Compression check https://www.ttforum.co.uk/forum/viewtop ... 5#p9175895
CSF radiator upgrade https://www.ttforum.co.uk/forum/viewtop ... 7#p9182367
Badger 5 Dyno run https://www.ttforum.co.uk/forum/viewtop ... d#p9189617
Front splitter, brake disc temp monitor https://www.ttforum.co.uk/forum/viewtop ... 3#p9198503
N/A inlet cams acquired with info https://www.ttforum.co.uk/forum/viewtop ... 1#p9199031
Castle Combe Performance German day https://www.ttforum.co.uk/forum/viewtop ... 3#p9203603
Water injection mapped with SSR on Ignitron https://www.ttforum.co.uk/forum/viewtop ... 3#p9213353
Bosch 044 fuel pump upgrade https://www.ttforum.co.uk/forum/viewtop ... 9#p9225569
Curbrough track day August 2019 https://www.ttforum.co.uk/forum/viewtop ... 9#p9225669
Donnington track day Sep 19 McCleans off https://www.ttforum.co.uk/forum/viewtop ... 7#p9231947
Intake cam change https://www.ttforum.co.uk/forum/viewtop ... 7#p9248827
Badger 5 dyno run with new intake cam https://www.ttforum.co.uk/forum/viewtop ... 1#p9249451
Santa Pod October 2019 https://www.ttforum.co.uk/forum/viewtop ... 9#p9252419
Turbo outlet pipe and Pagid RS4-2 rear pads https://www.ttforum.co.uk/forum/viewtop ... 5#p9269325
Silverstone Track day December 2019 https://www.ttforum.co.uk/forum/viewtop ... 1#p9273361
BYC rear wing install https://www.ttforum.co.uk/forum/viewtop ... 5#p9288325
Front wing mods and bonnet vent https://www.ttforum.co.uk/forum/viewtop ... 9#p9298379
Radiator fan single fan mod https://www.ttforum.co.uk/forum/viewtop ... 9#p9326129
SEM Motorsport intake manifold https://www.ttforum.co.uk/forum/viewtop ... 9#p9338319
HPA haldes controller install https://www.ttforum.co.uk/forum/viewtop ... 9#p9338779
Rear skirt trim and exhaust diffuser removal https://www.ttforum.co.uk/forum/viewtop ... 3#p9339263
Audi R8 coil upgrade https://www.ttforum.co.uk/forum/viewtop ... 7#p9355407
Heat insulation on tunnel https://www.ttforum.co.uk/forum/viewtop ... 3#p9356563
BTCC brake upgrade https://www.ttforum.co.uk/forum/viewtop ... 1#p9357061
Bedford Autodrome Track day https://www.ttforum.co.uk/forum/viewtop ... 5#p9369255
Wossner piston failure engine blow up https://www.ttforum.co.uk/forum/viewtop ... 3#p9384013
Engine rebuild Take 2 https://www.ttforum.co.uk/forum/viewtop ... 5#p9417305
Gearbox failure https://www.ttforum.co.uk/forum/viewtop ... 5#p9425085
Bedford Autodrome track day 2 https://www.ttforum.co.uk/forum/viewtop ... 1#p9430661
DQ250 DSG gearbox install part 1 https://www.ttforum.co.uk/forum/viewtop ... 1#p9444531
Badger 5 Rolling road on new engine rebuild https://www.ttforum.co.uk/forum/viewtop ... 3#p9445673
DSG steering wheel and temp sensor https://www.ttforum.co.uk/forum/viewtop ... 1#p9452571
Engine mount Poly fill https://www.ttforum.co.uk/forum/viewtop ... 1#p9457771
DSG gearbox testing https://www.ttforum.co.uk/forum/viewtop ... 9#p9458779
