Evening gents,
First time posting on here.
I currently have a 2005 TT (AUQ) FWD, which two days before returning back to work has decided to start then cut out with no reading of the ODO. The rest of the cluster works fine just no signal on either the left or right hand screen. I think it’s the immobiliser which has failed. I have tried to send the cluster off for repair but apparently it can not be repaired... (typical). I am now looking for a replacement cluster.
My question is to you ladies and gents, if I find a used cluster with a matching part number will that work on my car or does it also have to be from the same engine code too??
I also have a 225 BAM TT which I am currently restoring, I presume this cluster won’t run the AUQ?
Thanks in advance
