Lots of talk about coilovers/lowering springs and all the posts normally come down to personal preference. So I thought it would be a good idea to collect some info for those looking to buy a set of coilovers or lowering springs.
I can update this first post when you post info on this thread. Spring rate is not always straight forward, if it's progressive I think we can collect the final rates before the spring closes. Helper springs are normally fully compressed so I think it is useless to collect that data.
SI-units are the easiest so we will use those. I can convert if you have lbs/in or some other values. Kg/cm (N/mm also) seems to be the most common so will use that. Newtons (N) are also used here approximation 10N ~ 1kg is close enough.
Damping is another thing that effects a lot, but I think it is enough just to collect if there are adjustable dampers or not. Damping explains why some coilovers can feel harder even they have softer spring rate, but spring rate is a good starting point in decision making.
If someone has a bench to measure stock springs that would be great too.
Here we go, in alphabetical order for Mk1 TT Quattro:
Make:AP
Model:
Product number: GF10-041
Front spring rate: 70 kg/cm
Rear spring rate: 60 kg/cm
Adjustment: height (F/R)
Make: AST
Model: 4100
Product number: 4622S-0014-M1
Rear spring rate: 80 kg/cm
Adjustment: height (F/R), Rebound (F/R)
Make: Bilstein
Model: PSS9
Product number: 48-080422 / F4-GM5-8042-H6
Front spring rate: 65 kg/cm
Rear spring rate: 117.5 kg/cm
Make: GAZ
Model: GHA/GGA
Product number: GHA336/GGA436
Front spring rate: 58 kg/cm
Rear spring rate: 80.4 kg/cm
Adjustment: height (F/R), GGA rebound also (F/R)
Make: H&R
Model: Street
Product number: 29431-1
Rear spring rate: 108 kg/cm
Make: H&R
Model: Comfort
Product number: 29431-2
Rear spring rate: 90 kg/cm
Make: H&R
Model: Twin-tube
Product number: 35431-1
Front spring rate: 60 kg/cm
Rear spring rate: 114 kg/cm
Adjustment: height (F/R), rebound (F/R)
Make: KW
Model: Variant 3
Product number:
Front spring rate: 81.3 kg/cm
Rear spring rate: progressive, rate unknown
Adjustment: height (F/R), rebound (F/R), compression (F/R)
Make: KW
Model: Clubsport
Product number:
Front spring rate: 101.9 kg/cm
Make: ST Suspension (KW sub brand)
Model: Coilover kit
Product number: 90830
Rear spring rate: unknown (marked: 8012 14E11)
Make: Weitec (KW sub brand)
Model: Hicon GT
Product number: 13210041
Rear spring rate: progressive spring approx. 110 kg/cm
Make:AP
Model:
Make: AST
Model: 4100
Make: Bilstein
Model: PSS9
Make: GAZ
Model: GHA/GGA
Make: H&R
Model: Street
Make: H&R
Model: Comfort
Make: H&R
Model: Twin-tube
Make: KW
Model: Variant 3
Product number:
Make: KW
Model: Clubsport
Product number:
Model: Coilover kit
Model: Hicon GT
