After a few requests and as i recently made my own adaptors I've made a batch of Mk1 Audi TT Vent adaptors to allow you to fit 52mm gauges (Boost, Oil Pressure, AFR etc.) and still allow some air to pass around the gauge. These are a tight push fit so may not require gluing in place, however there's no harm in doing so for an extra secure fitment.
They are laser cut aluminium in mill finish and I've got 4-slot versions only currently.
I'm asking for £13.50 delivered to the UK which is cheaper then the US equivalent and should be with you faster! :lol:
You'll need to remove the vent from the dash first, you'll need to get just behind the metal ring with a small flat head or using your nails and pull out until you can get enough grip to pull the whole unit out.
Next begin to dismantle, starting with the two cogs on the side and the air control flap, until you are left with these two pieces and your adaptor;
Next you'll need to push the adaptor into the black plastic holder;
It's designed to be a tight fit, once you have it sitting in flush, use the metal ring to help push the adaptor back into place, it should be approximately 5-6mm recessed into the plastic. This allows fitment of the Metal ring;
Once you're happy that the adaptor has been pushed into place enough to allow flush fitment of the metal ring it's time to adhere the outer metal ring to the plastic (Some use clear silicone so this can be reversed at a later date if needed). Once this is done you can then install your gauge!
The design has now been finalised and fabrication has commenced. I should be collecting these tomorrow!
If you drop me a PM with your postage address and order quantity and i'll reply back with the Paypal address, to be paid for as goods and services as per Forum rules
For those who've already ordered and paid the adaptors have been sent first class in today's post.
Apologies for the slight delay in getting these sent out, I wasn't quite happy with the finish when they came back from fitting, so they've all been media blasted now to remove the burrs and any marks.
Hi George, I do indeed, at the moment I have 4-slots available to go. I'm assuming you won't have PM facilities as yet so maybe post your email address and we can sort it out via email?
Related Threads
Audi TT Forum
3.6M posts
79.5K members
Since 2002
