Spacer Spacer
  • Start
  • News
  • Forum
  • Advertise
  • TTOC
  • Search
  • About TTF
Board index   FAQ   Search   Garage   Gallery
Register  Login
Board index ‹ UK TT Forum ‹ TT Forum - MK1 TT (8N)
Badger 5 / oem airbox
Discuss all things to do with the MK1 TT 8N (1999-2006)
Moderators: John-H, DXN, Ikon66, T3RBO, Hoggy
Post a reply
25 posts • Page 1 of 2 • 1, 2
Terry63
  • Terry63's Profile
TT Forum Established Member
PostPosted: 20 Jun 2018, 17:18
Have a badger 5 TIP but am struggling to fit the oem airbox there just doesn’t seem to be any room ... I have a cone filter on at the moment but I just don’t like the noise it makes any tips for making fitting of oem airbox easier
Sent from my iPhone using Tapatalk
Remove Advertisement
Delta4
  • Delta4's Profile
User avatar
Too Much Time On My Hands
PostPosted: 20 Jun 2018, 17:32
It will fit, but the TIP needs trimming to make it work, or make a cylinderical enclosure for the filter to sit in, non offensive to the ears but does not impdede performance imo.
StuartDB
  • StuartDB's Profile
PostPosted: 20 Jun 2018, 18:31
you need to trim it if there is a heat shield too, otherwise the TIP compresses. dont trim the turbo end, you might want to leave the bottom loose until you rotate it into a relaxed position, when I just had a cone filter on the end of the tip it looked much more comfortable.
you could do what I did and put some foam on the bonnet above the heat shield to try and shield some of the sound.
TT Tom TT
  • TT Tom TT's Profile
User avatar
PostPosted: 20 Jun 2018, 18:52
Get a sharp knife and cut off an inch or so at the MAF end. You can cut nearly a perfect circle if you use your MAF and a jubilee clip as the 'stencil'.
400bhp+ ✅
Weight 1320KG ✅
300bhp/tonne+ ✅
Build took 2 years+ :lol: ✅
My build thread:
https://www.ttforum.co.uk/forum/viewtopic.php?f=2&t=1308217
TT Tom TT
User avatar
400bhp+ ✅
Weight 1320KG ✅
300bhp/tonne+ ✅
My build thread:
Delta4
  • Delta4's Profile
User avatar
PostPosted: 20 Jun 2018, 19:41
TT Tom TT wrote:Get a sharp knife and cut off an inch or so at the MAF end. You can cut nearly a perfect circle if you use your MAF and a jubilee clip as the 'stencil'.
You can say that again :) , i tried that did'nt work for me so install a huge cone filter instead then made a enclosure for it to keep the racket down :lol:
Terry63
  • Terry63's Profile
PostPosted: 20 Jun 2018, 21:00
Hi mate got any pics of the enclosure
infidel.uk
  • infidel.uk's Profile
User avatar
2000 Audi TT MK1 - 1.8T (quattro)
PostPosted: 20 Jun 2018, 21:05
im still to do this to mine after having it on the car 12 months, lol
but then i dont really feel like chopping it, makes selling it easier if i ever do, plus what performance gains are involved, if any ?
Audi BBTTT MK1 / K418T / 309 B.H.P / 298 Torque / Tuned By WAK / Audio By P.S sound
Delta4
  • Delta4's Profile
User avatar
PostPosted: 20 Jun 2018, 21:50
Got pics but it's so simple to put in words, have a look at the forge mk4 r32 induction kit, the cylinder part of the kit i made from a sheet of black plastic, it's a snug fit over k&n s2000 filter
StuartDB
PostPosted: 20 Jun 2018, 22:18
infidel.uk wrote:im still to do this to mine after having it on the car 12 months, lol
for someone with a beach buggy hybrid turbo, if you really dont believe the oversized TIP adds anything put back the stock one and get it mapped to see if it reaches the 309bhp you have?
infidel.uk
User avatar
PostPosted: 20 Jun 2018, 22:35
:lol:
quite right too, but i was meaning the cutting of the tip, as suggested on this very topic. 8)
StuartDB
PostPosted: 20 Jun 2018, 22:43
Aha... I needed to trim mine to fit otherwise out was kinked.
HOGG
  • HOGG's Profile
User avatar
PostPosted: 21 Jun 2018, 07:56
No trim needed on mineImage
Sent from my SM-G930F using Tapatalk
Going for 300bhp with just bolt on upgrades.
Delta4
  • Delta4's Profile
User avatar
PostPosted: 21 Jun 2018, 14:44
[quote="HOGG"]No trim needed on mineImage
That'll be down to the space saving air filter that you've fitted :lol: :)
StuartDB
PostPosted: 21 Jun 2018, 14:55
also HOGG got his TIP all the way up to the MAF Sensor - do you not have a lip? <-- that is not supposed to sound like a "and that's what she said moment"
Next
Post a reply
Return to TT Forum - MK1 TT (8N)
Who is online
Registered users: 47yellow, albe0876, base86, Bing [Bot], Blue lightning, Daz1968, DJTS, fatty225, geira, Google [Bot], Google Adsense [Bot], happychappy, Harm_1, Jannerman, Majestic-12 [Bot], Outnumbered, piti, Szulkarn, twofourten, vpapanik
Switch to mobile site
  • Board index
  • The team • Delete all board cookies • All times are UTC
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
© 2000 - 2010 All Rights Reserved, VerticalScope Inc. :: © TTForum Style designed & coded by Christian Bullock
Terms of Use
Copyright
Privacy Policy
Do Not Sell My Data
Manage Consent
