Morning all,
Having issues with major condensation in the car which is probably what destroyed my Bose amp.
After a very cold night every window inside is covered so badly in condensation that the water droplets run down the windscreen.
After a long time checking for leaks and damp carpets (drain holes all clear, carpets dry) i finally discovered that the water appears to be trapped somewhere in the doors, mainly the drivers door. I've followed the advice for checking the square drain hole at the bottom but it's perfectly clear.
I know some posts on here ask about water smears on the inside of the windows when winding the window down and back up after rain or washing the car which i've always experienced with my car..... But now, when i wind the window down the entire pane of glass is entirely smeared in water and it's been sitting in the door for so long that it smells terrible of stagnant water. Really not pleasant! Also, the inside seal against the window is starting to look mouldy.
Any ideas where the water is getting trapped and how to solve this please? Tempted to pour bleach inside to sort the smell it's so bad!
Thanks,
Nick
Thanks,
Nick
