Hi,
I have had quite a journey with this mk2 TT and its driving me mad and draining my wallet.
I love the car but it seems to always give issues, and this one seems to be a big one.
I have recently done an oil change, in April and the car has been used about 2-3 times a week since then, I also did 5 Launch control launches within 30 minutes back in April, never done them before so I played around on a empty road no serious speeds and not going over the limtit but just to feel how the stage 1 works and how the car spins, was trying to feel how the car spins and if P4S tyres would reduce that spin as it just goes crazy, was perfectly fine after those launches back in April, recently I noticed the shaking more than normal last week, in Park and netural its pretty shakking and the seats move and the engine is really shaking, doesnt shake in Drive or sport or reverse, noticed a noise from the DSG area so thought its time for the DMF and clutches (80k miles), this morning i was going to take it to a garage to get it done, and the car started and it sounded like a go kart, it was misfiring and popping sound and popping smoke on a cold start like a machine gun, garage has not seen anything like that, car has lost a bit of power and it doesnt feel right and there is a noise towards the back of the engine. They suspect its the Balance shaft thats gone, they cant guarantee the £1650 balance shaft repair will repair whats going on as they have never seen this based on all the stuff I have had done already.
Im looking for some thoughts before I scrap the car as i cant afford a balance shaft and oil pump replacement and a DMF and clutches and then the possibility of it not working.
This is what i have done in the last 10k miles / since July 2021 when i got it:
-Timing belt with water pump
-DV
-Boost pipe
-Irdium spark plugs
-5w40 oil changes every 6 months
-APR coil packs
-DSG service was done Jan 2021
-Stage 1 map as the one on there was causing fuel cuts
-Cam chain
-PCV
-Charcoal canister
-Cam tappet
I have spent loads of money since July 2021 and its disappointing to see it has a new issue everytime something new gets changed, most of the work done was to prevent future issues, only thing that i have not done is the pick up pipe, injector clean and carbon cleaning, doubt this much of shaking is due to that, had a slight shake since i have had it and i knew that was the carbon build up but this seems to be a bit extreme for that.
Looking for some help/advice, maybe I am trying to find reasons to keep this car, I am about £10k into this car with the price of the car and the repairs, not sure if im willing to just let it go but i got £3k offeres for the car when it was working so im at a loss here.
Thanks.
-DV
-Boost pipe
-Irdium spark plugs
-APR coil packs
-Cam chain
-PCV
-Charcoal canister
-Cam tappet
Thanks.
