1 - 15 of 15 Posts
2009 2.0TDI CBB Quattro Roadster
Hi my latest issue is the passenger door, been on holiday came back passenger door wont open lock not making any noise either with fob or key, window wont go down and of course roof wont work. thought id take door card off but cant get it off without the door open. obviously some issue with the motor or control unit and i can replace these but ........
how do i get the door open ?
Have you checked the status of the car battery as it’s been left stood whilst you’ve been o holiday? - might be quite flat…..
yeah drove it for a few hours drivers door etc works fine wont even open with handle from inside or drivers unlock button
got the door card 3/4 off last two clips wont budge in corner of dash but even then i still need to open the door after that
TTS 2010 Stage2+, Cup 2 Connect, Millers NT+, K-sport BBK
Assuming you can get to the door's cable loom, maybe the lock actuator is electrically activated and you apply the right current to the right cable it will open?
Sadly the dealer will take some £100 just to say "oh look your door is broken" but maybe they will know the solution?
2007 3.2 VR6 Quattro Roadster
Could be a disconnected bowden cable. There's a TSB on this I believe for early Mk2s. Link here.
An OBDII fault scan is always a good idea to see if there's any faults being reported as it could be a defective or damaged wire in the door loom powering the lock mechanism if there's no sound of the actuator operating.
Put fresh batteries in your fobs and give that a try first. Sometimes the easy solution is the one most overlooked.
See if this post helps -
If the window won't operate either then it sounds like it could be the wiring loom to the passenger door as there's no electric supply going to it. The problem is, it will be double locked so I don't think that post will help but anything is worth a try. You can't open it from the inside and there's no key hole on the outside to unlock manually which on the drivers door you do have.
I had the same issue a couple of years ago. I couldn't find anything online (No secret key hole to unlock it manually) and could only see posts suggesting that a hole is pretty much drilled to get to the lock! It turned out to be that the plug which connects the wiring loom from the car to the door near the door hinges came loose and was probably a case of the garage not properly plugging it back in after having the door off for a lock repair. Luckily for me, i hit a bump in the road which knocked it back into place just enough to bridge a connection and press the door unlock button. It's only then that i discovered the cause and resolved it from happening again.
I'm not suggesting you risk damaging your car in every pot hole on the road though trying to get the same result though...... :D
Not sure without going out and having a look at my door as to whether there's a gap between the door and car body to get something (Which won't scratch the paint) inside the gap to nudge the socket? Sorry i can't be of any more help but i thought i'd add my own experience of looking into this when i had similar symptoms.
Discussion Starter · #9 · (Edited)
scan says door control module faulty
so still have to get the door unlocked got all the clips out from the door panel disconnected the handle cable but cant get the panel over the speaker metal bracket may i may have to jam the door card open and take the panel off for the cables and hopefully get into the lock that way, scraped arms and torches and mirrors going to be needed i think
so took drivers door card off to see if there is a way from inside the door to manually override but cant see a way to do it so not much point taking door card off at all .
wiggled door wires in door jam with a plastic ruller didnt make any diffrence.
still stuck hoping WAK will share some of his tricks
well still stuck door card still jammed vcds no response from controllor so output tests to try to get it open wont work either just dont want to destroy the door card or the lock to get it open
Discussion Starter · #12 ·
managed to get the door open good job i found a spare lock just chiselled it to bits to get it open and a big hard very hard pull got the door card off over the speaker bracket, so new lock doesnt work either but door is open heres a scan of the car all ok been removed to save data for site . most of it points to passenger door module but noticed also saying drivers door which works fine
Friday,05,August,2022,16:37:56:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 22.3.1.0
www.Ross-Tech.com
Mileage: 110750km-68816miles
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
26-Auto Roof -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Cannot be reached 1100
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AG HW: 8J0 820 043 AG
Component: J255 Klima 1 Zone 0080
Revision: 00H08006 Serial number: 00000001104173
Coding: 1049876
Shop #: WSC 01236 785 00200
VCID: 6BD572AB4A85F9D306-803E
1 Fault Found:
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 126
Mileage: 110753 km
Time Indication: 0
Date: 2022.08.05
Time: 16:29:54
Freeze Frame:
ON
Bin. Bits: 111111
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008796698
Coding: 01000E8280141C804F1800001800000000085E075C210802000000000000
VCID: 489FED273BB3F2CB4B-801C
Subsystem 1 - Part No: 8J2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00064784
Shop #: WSC 01236
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 126
Mileage: 110753 km
Time Indication: 0
Date: 2022.08.05
Time: 16:30:00
Freeze Frame:
ON
Voltage: 12.15 V
OFF
ON
OFF
OFF
OFF
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K086268624
Coding: E9821F261006025101
VCID: 356194D35C417F2320-8060
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 126
Mileage: 110753 km
Time Indication: 0
Date: 2022.08.05
Time: 16:30:52
Address 26: Auto Roof Labels: 8J7-959-255.lbl
Part No: 8J7 959 255 D
Component: 256 VSG TT H19 0140
Shop #: WSC 00000 000 00000
VCID: 408FF5071383CA8B83-8014
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 50
Mileage: 110753 km
Time Indication: 0
Date: 2022.08.05
Time: 16:32:15
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8J7 959 801 E HW: 8J7 959 801 E
Component: Tuer-SG H02 0060
Coding: 0000565
VCID: 3E738BFF6977BC7BF1-806A
3 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
012 - Electrical Fault in Circuit
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal
Address 46: Central Conv. Labels:. 8J0-959-433.lbl
Part No: 8J0 959 433 B
Component: KSG H11 0080
Coding: 1890300241182D098505489AD633
1 Fault Found:
Address 52: Door Elect, Pass.
Cannot be reached
For info on these and other faults, run a Google search for "Ross Tech xxxxx" where xxxxx is the fault code. If they have one published for that code, it will provide possible causes and solutions -
01331 - Ross-Tech Wiki (Note this is for the Driver's side since 01332 doesn't seem to be listed)
012 - Electrical Fault in Circuit​
008 - Implausible Signal​
004 - No Signal/Communication​
I would start by carefully inspecting the wiring loom inside the grommet between the A-pillar and door. Broken wires in there are not uncommon.
Hood Automotive lighting Motor vehicle Automotive design Automotive tire
Discussion Starter · #15 ·
well here is a update and it might help others
I had inspected all the wires in both door jams and they were fine but i tested the wire going into the door control module and that was ok but there was no live coming out to the lock, the mirror or the window switch so took the window motor out split it from the module and spent a good hour tracing the fault in the module and it was 2 components, (so was the module) I then ordered a replacement giving the part number on the motor , this part number will not do alone the module part number and the motor number have to be the same, (coupes have different module also) you can just replace the module very easy to split but seller would not split so i just put whole lot on, scanned car again historic faults do not clear by themselves with the replacement even though the whole lot works so cleared in vcds and all's fine
bob
1 - 15 of 15 Posts
