1 - 20 of 22 Posts
apparently, the function is present, but can't change the std value (100%), it doesn't accept the new value (tried with 0, 10 ecc)
strange, the same VCDS worked in coding my TTS sound actuator to zero… :unsure:
2007 3.2 VR6 Quattro Roadster
This is from the Mk2 if it helps -
Wheel Automotive tire Motor vehicle Automotive design Alloy wheel
I know how to disable it (I did on my previous TTS), what I want to know is if TT-RS has it or not...
I can see the sound actuator volume in the adaption list of A9 module, the default value appears as 100% (as it was on my TTS in OEM trim), but it doesn't accept a new value (tried with 0%, 1%, 5%...), so can't understand if is a VCDS problem or simply sound actuator is not present and the adaptation is present by default
OP you answered your own thread title in your first post. Yes it has Soundaktor
not sure, I am having conflicting opinions from other Audi forums
Might try via OBDeleven maybe?
Also, can’t be 100% certain. But what car today doesn’t have engine sound enhancer…
Big possibility that it has.
Still try OBD, maybe VCDS is bugging out.
Or check under the hood. From what I remember, it’s fairly easy to locate it.
I don't have and use OBD 11 (I am a VCDS fan:LOL: ) but I have friend who use it, so worth a try...
the sound actuator in TT acts via the central speaker place on the console, apart this I believe it's just a sw (no other mechanical parts), if so, difficult to figure out if present or not.
investigation continues...
For me, no sound actuator on TT RS...
Discussion Starter · #12 ·
does "for me" mean that you believe there is no sound actuator, or that you confirmed yours don't have? just to understand
I believe it.
I'm sure I've actually read somewhere that the RS is the only TT that doesn't have it as it doesn't need it being a 5 pot. Also, I having driven a TTS for some years with the sound actuator and would say you can detect a sort of manufacturing with the noise in the cabin but certainly not with the RS.
Put a microphone or recording device on the speaker in the middle of the dash and record while you drive round a bit. If the recording has a pronounced engine noise then you've got a sound actuator at work.
I hope you're right...
Discussion Starter · #18 ·
it can be a good idea…
tried to auscultate :geek:, but apparently seems nothing comes from the central speaker...
If people who own and drive a TTRS aren't sure if there is a soundaktor then either there isn't one or it's so well implemented that you can't tell. If the former then the sound is real which is good. If the latter then that's good too as you can ignore the fact that the sound isn't real. So whether there is one or not is a non-issue.
Discussion Starter · #20 ·
this is philosophy :D, I would prefere practical answers, like yes there is/no there isn't… :sneaky:
as I said, apparently no sound is coming from central speaker, but the adaption is existing, default value set to 100%, and no other values are accepted, that's why my doubt.
From '20 YM audi locked several functions (i.e. start&stop), and might be the same even for sound actuator
1 - 20 of 22 Posts
