thanks, too soft if rears 26psi ?powerplay said:I normally have my fronts about 32 and rear about 28 psi
I think my door sticker shows 32 for the front and 26 for the rear, which is what I use for my 19s. I have quattro if that maybe affects the rear pressure.bluetone said:26 psi in the back sounds a bit soft to me...
this is what my tts says also,one person no luggage,think its 33F 30R with 4 persons or luggage,i think i tried the rears at 30 for a while because i thought 26 was to low,ended up scrubbing the inner edge of the tyre off,went back to 26 its been fine sinceScoobyTT said:I think my door sticker shows 32 for the front and 26 for the rear, which is what I use for my 19s. I have quattro if that maybe affects the rear pressure.bluetone said:26 psi in the back sounds a bit soft to me...
Means you didnt order 19s with the car.jobe said:can anyone assist me with correct front/back tyre pressure for 255/35-19 Michelin PS2 RO1?
my TTS Coupe door sticker has just 17 and 18" values.
thanks
Can't say I have, are they Audi wheels? I'd be looking at the offset as the actual diameter will be correct, so if they are grounding the bodywork it sounds like they are too far in or out.bluetone said:Has anybody else experienced this?
Hi, they are ET 42, A5/S5 rims that I have seen that other users on the forum are using.wja96 said:Can't say I have, are they Audi wheels? I'd be looking at the offset as the actual diameter will be correct, so if they are grounding the bodywork it sounds like they are too far in or out.bluetone said:Has anybody else experienced this?
no, but i bought orig Audi 5star double spokes, used, from a TTS owner.Toshiba said:Means you didnt order 19s with the car.jobe said:can anyone assist me with correct front/back tyre pressure for 255/35-19 Michelin PS2 RO1?
thanks
