1 - 11 of 11 Posts
Hi All,
Changed my filter for a panel filter (lightly oiled) and its run for a week and then all of a sudden the other day the traction and ABS lights illuminated. This didnt affect the drive and when I plugged an OBDII reader in there were no codes. It seems slightly intermittent and usually comes on when you are accelerating. This morning the idle was a little lumpy and the engine a little hesitant until warm. The rest of the journey was fine after it had warmed up. I was thinking its maybe MAF related but I thought I would come on and ask if anyone had experienced similar. From the searches I have done it seems most people had fault codes show.....
Any help is greatly appreciated.
Seems funny that it has started to run a little lumpy though. Surely that would not be ABS pump related. Could be two different issues. Is there anyway to check if the MAF is faulty or failing?
Mafs don't like oil!!!!
Try unplugging the maf and then see how it runs
Yes I know MAF's are not big fans of oil which is why I kept the oiling to a light minimum. I have a feeling that this is what has caused the issue but I am not 100% sure. Its going in for some diagnostics and leak testing with Wak tomorrow so hopefully all will get sorted.
I did have all the wheels off recently to freshen the calipers up a little so its also a possibility. I will check later...
lordlee said:
I plugged an OBDII reader in there were no codes..
Its possible a generic obd reader will only check for ECU faults and you'll have a fault on the ABS controller hence why you have no codes.
I'll check advise you tomorrow.
I have done a VCDS lite scan and it says the following:
00283 - ABS Wheel Speed Sensor Front Left (G47): Mechanical Malfunction
Possible Causes
Excessive Air Gap between ABS Wheel Speed Sensor Front Left (G47) and Rotor
Short Circuit in Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
ABS Wheel Speed Sensor Front Left (G47) faulty
Possible Solutions
Check ABS Wheel Speed Sensor Front Left (G47) Installation
Check Wiring from/to ABS Wheel Speed Sensor Front Left (G47)
How do I check the air gap?? Also there was resistance from the wires at connector level but I didnt check at ECU level as I cant find where to check that. Anybody any advice of what to do next? Change the Speed sensor again as its an ECP supplied one?
Discussion Starter · #11 ·
I am wondering if its worth changing the ABS speed sensor wiring harness as it seems like the logical next step. Anyone have a working one lying around at all please?
1 - 11 of 11 Posts
