Hi I need at little help as I can't get my ac comp out :-|
I have removed the large bolts going in from the front, but it won't budge at all, what am I missing?
F
Answering my self here, but it might help somebody else down the road. The compressor is very tight in the bracket so I ended up removing the alternator so that I could get a pry bar behind it and work it loose. Then dropped it out thought the bottom( also removed the Sai and Pas pumps to get some space to work in.)
Wow seen the picture of the pump, good to see its going ok, bit late now but I find if you put paper down and lay out the parts you remove in order, then when you come to put it back together I just do it in reverse,
That's a good tip, I use an iPhone app and take pictures and ad pins with notes. That way I can plan my reassembly and maybe put together a how to or two if needed.
1 - 5 of 5 Posts
