1 - 3 of 3 Posts
It worked in this morning without a prob but It doesnt work anymore, theres no fault codes neither. Should fans start to spin when air con is on? I can hear compressor going on and notice it by dropped engine speed for a sec. From where to start look for fix? Are there fuses for air conditioner fans?
All help is appreciated!
Hi Mat, Fan should run when aircon on, Check fuses etc on top of battery.
Corrosion & burning is fairly common, even if fuses still O.K.
Thanks Hoggy! Broken fuse was causing problem. Looked fine from top but was hard to remove... noticed corrosion and some melt plastic so it has been quite hot. New fuse and air con is working.
1 - 3 of 3 Posts
