It has come to my attention on another thread that "Some" people belive that Brake Fluid changes were done every 2 years in the 70's and that it's a sealed system and doesn't need changing as regular..
PLEASE will you all check your service books.. Also the TTshop website states:-
So can you all check your not running with Old Brake Fluid.. it's a safety thing, and was quite alarmed to hear the comment !!
[/quote]TT SHOP said:Every 2 years (regardless of mileage)
Brake Fluid (Pressure Bleed) Change - £49.99
It is important to keep up to date with brake fluid servicing. A car with old brake fluid can be dangerous as the brakes will not work efficiently.
Performance Brake Fluid (Pressure Bleed) Change - £69.98
We also offer an upgrade to a higher spec performance fluid with a higher boiling point. Ideal for fast road use and track days.
This is a Millers Racing 300 performance fluid.
