1 - 14 of 14 Posts
pepe88 said:
My battery light came on tonight along with the ABS and ESC lights. I tested at the battery posts and got a little over 16.5 volts.
If it charging that high. I would say the alternator is healthy and it just need a new regulator!
pepe88 said:
It is over 10 years old now with around 100K miles. I figured it was time for a whole new one. Looks like I'll try the VR first though.
The VR is a lot cheaper and DIY and if it isnt broke then why fix it!!
shame u aint anywhere near stoke i no a guy who fixes them like new and hes cheap cheap
Hi, Is battery good & connections at battery tight & clean, because a poor battery can cause high volts, as an alternator requires a stable 12v ish to charge properly.
I think all the connections are good. I just put a new VR on and put everything back together. Now it shows FUSE above the mileage in the odo. What did I do wrong....?
Blown a fuse? I think the fuse that causes that light is fuse in the end of the dash. Check the fuse is might be simple
Sent from my HTC Desire S using Tapatalk 2
Hi, "Fuse" can display if battery has gone flat. Will she spin over.
Discussion Starter · #11 ·
The battery seems to be dead. It's strange because the battery is only a few days old and it was starting just fine before I put the new VR on. The battery light was on though when I last shut the car off before changing the VR. It set for 3 days with the neg cable off while I was waiting for the part and time to put it on.
1 - 14 of 14 Posts
