My Gauge shows 70 all the time. The 49c check shows whatever the gauge shows so its complementing each other, but thru computer check at worksyop, temp shows 90.
When engine off, at times the fan stays on to cool down engine (although gauge shows 70 all the time)
my fuel consumption seems fine. I get approx 500 kms for a full tank. but at times i feel as if the power is not as ooomph! sometimes ok, i feel the turbo pull, sometimes pull not so great.
so what cud be the problem? is it the thermostat? coolant sensor? or dashpod gauge? The worksyop seem to think its the dashpod gauge faulty.
no fault showing in the computer.
Anyone with same symptoms??? pls help. Im just getting paranoid not nowing the real temp in case of overheating.
