1 - 7 of 7 Posts
Hi there guys my m8 has rung me tonight , he's just bought an 03 plate 150 roadster. He told me he got to 80 miles an hr the a circle with a line through it came on the dash. An old chap owned it before him and must have programed it in, I've had 3 tts and never come across this, any advice about removing this would be gr8 thanks.
Steve
I know that you can find that info inside the handbook that should have come with the car... I know that you can set two speed warnings. One is temporary and I think one is remembered after an ignition off. I'm sure someone will be along to tell you how to sort it :p
Nick
According to the handbook...(if its the speed limit warning function)
Press the test button on the dashboard (the small silver button used to reset the odometer) with the ignition switched off. Press the test button agin and hold for at least 2 seconds. the display will show the speed limit currently set. Now press and hold the Reset button on your right hand stalk until the cross out warning symbol appears.
T3RBO said:
To remove
Speed limit 1 is
Press the 'test' button for at least a second when car is moving above 5mph and it will clear
Speed limit 2 is
Ignition off, press 'test' button for 2 seconds, then with warning showing on DIS press and hold 'reset' button
NAH,, DONT HAVE ONE !!! :D :D :D
1 - 7 of 7 Posts
