stevejoy5 said:
2.55 bar on the boost sensor, sorry but i dont understand i know a little on cars but are you saying the sensors bust or i need to up grade.
cheers. where shall i start checking the hoses theres millions to choose!!!! the boost doesnt fluctuate at all as i would expect with a leak. it stays at 4psi constant never more or less when you accelerate
Ok that was confusing additional info... the sensor on a TT which measure the boost for the engine management will only register up to 2.55bar so thats the maximum you can boost to - 1.5bar in 'real' boost since 1bar is atmospheric pressure.
As to your issue... there could be other reasons for hesitation:
coilpacks - the individual ignition coils for each sparkplug - can go faulty and give hestitation under load;
MAF - the Mass Air Flow sensor, tells the engine management how much air is being sucked in so it can calculate the fuel load needed... if thats giving an intermittent or low reading the fueling will go too rich and cause hesitation until the lamda sensors in the exhaust tell the management system to back off the fueling...
but, if your boost is only 4psi I'd say you're looking at a boost leak.. a split in a hose will remain closed until the pressure hits a certain level then will act as a valve so the boost wont increase above that level. The hoses are the big ones to the LH side and back of the engine (the chargepipe - takes pressurised air from the turbo to the LH intercooler), then there is a pipe from the LH to RH intercooler and from the throttle body (front of engine, right hand end of the intake manifold) to the RH intercooler
A picture: the red bits are the pipes mentioned above and/or where common leaks occur on the connections between the rubber hoses and the metal parts
