1 - 14 of 14 Posts
Superpro bushings are so easy to install with some grease
Purple Violet Material property Electric blue Wood
Hand tool Metalworking hand tool Tool Wood Stonemason's hammer
Sent from my GM1900 using Tapatalk
Can't believe that 20 years old rubber is still in good shape.
Automotive tire Automotive lighting Wood Bumper Motor vehicle
Glasses Automotive lighting Goggles Wood Gas
Because there is 4mm length difference between upper and lower arms.
I decide to swap them to correct the camber more.
Liquid Wood Fluid Water Gas
It will go to shop for properly calibration after every thing is done.
Compare polyurethane and normal rubber bushings, I prefer rubber bushings.
Every one has different opinions and experiences.
Discussion Starter · #13 ·
Compare to the rubber bushing dog mount, I prefer the rubber. What a another waste.
Automotive lighting Hood Motor vehicle Automotive tire Drinkware
Font Blank media Circle CD Audio equipment
Replaced the 4wd fluid, Bended the nozzle but it doesn't work out so ended up with screw driver to put it in with no problem.
Took a while to screw the new filter, scared to cross threads. What another great over engineered German design.
Fluid Wood Tool Gas Office supplies
Water Wood Gas Close-up Metal
Cylinder Gas Wood Paint Building material
Automotive lighting Hood Motor vehicle Automotive design Vehicle door
1 - 14 of 14 Posts
