1 - 7 of 7 Posts
Hello, I just laid on new users of this forum.
I wanted to ask you about a problem I have in the back of my car.
I have a kit from H & R coilovers at maximum low.
The back has an excess of bouncy and very annoying (and dangerous I think).
It seems that the cushions are very soft. Changing a koni shock absorbers are adjustable solve the problem?
I also read on this forum about the 600lb AFCO springs.
Can anyone help me? thank you very much
I had the same dangerous issue. Raised the height 20mm or so and the suspension has a bit of breathing room to absorb the bumps. No more offs on high speed corners with dips in the road :) still looks OK but probably would benefit from spacers & 19s.
So whether or not a more expensive setup with adjustable rebound helps which is the first thing I thought - fiik.
Sent from my Nexus 7 using Tapatalk 2
NEB Hello!
A user from another forum was provided to help me and recommended special order springs brand h & r, of 913 LB ...
Neb questions:
If you raise the car's floor and let the wheels hanging, has clearance from the top down?
I will not rear hangers and if I put the rear wheels in the air I can raise and lower the wheels about 8 cm.
The spring hangers have no space between the top and the dock.
1 - 7 of 7 Posts
