Hi,
I bought a brake rewind tool for audi's from halfords, the rewind adapter with the pins has a set of pins on either side, one set on a larger p.c.d and the other on a smaller p.c.d i had to use this tool as a "pusher" and had to grind off the two pins on the larger p.c.d what ones do you actually use for the TT? Just i dont want to find that its the ones i have ground away before i start to do my brakes!!!!
thanks
thanks
