1 - 20 of 22 Posts
Hi all,
Just washed a load of sahara dust off the car and banged the antenna (not very hard) and it broke off. Got a feeling it might have been glued together. Anyway I'm trying to work out what exactly has broken. Is it the male threaded bit on the end of the mast or the female threaded bit on the top of the amplifier? See pictures:
Hoping it's the cheap bits!
Jez
p.s. I did find this thread and I THINK it's the make threaded part broken inside the amplifier female thread. Sounds like fun getting the broken bit out :-(
Wood Wood stain Material property Flooring Hardwood
Paint Font Painting Circle Art paint
You might be able to reverse drill the threaded part out and replace just the antenna but would probably be worth just getting an upgrade stubby kit and sorting that bodywork while it's out.
So in your opinion, the male thread has broken off the end of the mast and is inside the female part on the amplifier?
Looking at a new mast, the threaded part seems to start at the face of the mast bottom, so it might be that the female part from the amplifier has sheared off and is tight on the threaded male part of the mast. (I can't shift it, but it's soaking in wd40...) What do you think?
well if that goes directly into the amplifier i would avoid drilling anything. Just take the whole assembly out and go from there i guess.
EDIT looking at pics on ebay and such it looks like part of the base unit is snapped off and stuck on your antenna threads. unfortunately that will mean a whole new unit i think which is the amp aswell. £115 new but breakers should have them much cheaper.
2007 3.2 VR6 Quattro Roadster
You might want to contact JonhhyFarmer as I seem to recall he's replaced the antenna amp. Unfortunately, from the pictures you've included, it looks like the threaded feature that the antenna screws onto is a significant part of the amp and probably can't be repaired.
The Workshop Instructions in the link you included are pretty straight forward, but it looks like a PITA got get to it.
OK, I've been hacking at it. It was certainly the female end (amplifier end) that has broken. I've removed the broken bit from the end of the mast and got back to a clean male M5 thread on it. Hooray I saved the £15 part and it's only the £115 part I have to replace! But as it's toast anyway I'm going to try and drill and tap the amplifier end and fashion some sort of threaded pillar to join the two...
Jez
Wood Auto part Household hardware Electric blue Metal
Water Terrestrial animal Snout Seal Electric blue
Water Line Gas Rim Electric blue
Reactions: darrylmg
Well I'm always up for a bodge lol. You could get a suitable threaded insert. Solder it to the metal inner part of the base. Then pour epoxy to fill the void surrounding it. Don't do that though.
Already ordered some brass pillars! Going to try drill-and-tap.
Discussion Starter · #12 ·
I broke mine too. I ended up buying and replacing the whole thing. I think that's impossible to glue this together and retain functionality.
Yup, I’m resigned to buying another but costs nothing to play at fixing it!
How difficult was it to access and remove/replace?
Jez
Etka: 8J7035501- Roadster Antenna Aerial:
Ouch, that's not cheap! I think if it were my car I'd just leave it off haha--never listen to [terrestrial/OTA] radio anyway. Would have to do something to fill/cap the hole or whatever but I'd def. do that before buying a new antenna module.
Thanks for the PM - I had to replace it in the end. Temporary and cosmetic fix was non-functional. I drilled down the centre conductor towards the amp - tapped a thread and screwed the antenna into it. Once replaced with antenna and amp from eBay the signal was so much better that I started listening to terrestrial radio! I think my photos are in a previous thread- I will post the link.
Discussion Starter · #16 ·
OK, I fixed it and I think it's fully working. (Well I can receive all the usual radio stations but with the diversity function of the RNS-E and the 2nd antenna in the boot it was still receiving fairly well with no aerial at all)
I got a brass pillar with M4 threads and retapped the female end M5 to fit the aerial screw.
Black Rectangle Wood Road surface Flooring
Musical instrument Wood Flooring Line Pattern
I drilled and M4 tapped the broken socket of the aerial amplifier and screwed it all together.
Automotive tire Gas Circle Tints and shades Auto part
For mechanical stabiity I mounlded some Sugru where the original plastic was and refitted the conical shroud.
Gas Household hardware Auto part Circle Metal
Hand Gas Auto part Circle Cylinder
Screwed in the aerial and hey presto!
Automotive parking light Automotive tail & brake light Vehicle Car Automotive tire
Product Font Screenshot Web page Number
That's some real nice handiwork there! :)
I'd never even heard of this Sugru stuff TBH. Looks like it's kind of like JB Weld putty but instead of hardening like metal it sets and remains soft/flexible? Will have to keep that stuff in mind in case I ever have such a use case!
Discussion Starter · #20 ·
Yup. Rather than explain just Google it… 😀
1 - 20 of 22 Posts
