The black Plastic under the window wipers has been split by some heavy handed mechanic replacing the pollen filter i think. As this plastic, covers roughly the location of the ECU do you rekon water could now get to the ECU?. Im assuming the plactic was keeping the water away from the ECU and other parts as it does seem to have a drainage route.
(Its the long piece of plastic that sits at the bottom of the windscreen, to get it off completly you need to remov the window wipers)
What do you rekon?
What do you rekon?
