1 - 13 of 13 Posts
Nope...
Seriously!!!!!
I thought you could, I'm starting to have 2nd thoughts about this car.
Yep, np look in the kb i did one of my V6s back in 07 and then the TTS in 08.
No prizes for guessing the films...
Bourne films, so Tosh, does this mean it plays DVDs or do I need some other expensive kit?
You cannot play DVDs by simply putting a disc in the RNS-E DVD Drive (where the nav disc would go), you need a multimedia adapter such as the IMA from Kufatec. This allows you to connect 2 extra devices eg. DVD Player, iPod kit or TV Tuner and control through the RNS-E. You also need VIM for full functionality which is not available currently for MY10 or newer units.
Toshiba said:
50% right, the 2nd ones Harry Potter.
As above you need to get the images into the RNSe
http://www.kufatec.co.uk/shop/product_i ... ation.html
I used my iphone rather than a DVD player.
Tosh,
how is that fitted, should I buy it and ask Audi to fit it for me?
Can you show pictures of where it goes?
Is it next to the AMI port?
I'm sure I'd done a write up on it, but i cant find it right now.
its basically power and can high/low from the quadlock connector in the head (or anywhere else)
One end then goes to the IMA box which can be seated behind the head or glove-box, the other end into the grey RNS feature connector. You then use a standard iphone/pod phono to jack (red,white yellow) from the IMA to somewhere in the car so you can plug in the phono. update the coding on RNS to have TV (8 or 9) bobs your mums sister!
I'll post the link later when i can look properly.
send me your email address and I'll send you the supplied manual.
If you look in the pic you can see the white phono jack coming from the iphone.
Cheers Tosh
if you get the bits i'll help you do it.
1 - 13 of 13 Posts
