I had the engine light come up today, the engine was not running rough at all, so I drove home carefully, not allowing the turbo to generate boost as much as possable, and hooked up my VAGCOM.
I got the following faults:
Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Bank1: O2S (Lambda) Correction Behine Catalyst: Crontrol Limit Reached
When I cleared the errors via the Vagcom softwear, the tickover became less smooth.
Would the D.V. be the dump valve, and is it possable to clean / check this futher?
It is a standard early 2001 180 quattro.
Thanks in advance for any suggestions!
