I am very interested in this, as you have the same module, same software version too, as my "new" oneI have a 2010 TTS and I have the rev "D" module.
I've not yet tried to enable HHA but it would appear that I should be able to as all the rights numbers are there in ODBeleven.
How can I check for the brake booster sensor?
I can try out the coding tomorrow lunch time.
Screenshot of ODBeleven for pleasure:
Notice the SW version is 0030.
Like Wolvez asked, I would be interested to know if you have the brake boost sensor (tricky to see on RHD cars) but it is under the fluid reservoir. Maybe easier to access with the 4 cylinder engine/layout. I will check mine tomorrow
What PR code do you have (the sticker of codes in your service manual, should have either 1AS or 1AT)
To try enabling it, add 2048 to your coding, then go to adaptation channel 58 and put in either 1 (normal), 2 (early) or 3 (late). This refers to how many revs are required to release the brakes. I would try 1 first. Then obviously you will need a hill
