1 - 3 of 3 Posts
Anyone know if it's possible to adjust the idle speed during the cold start period?
As you may have picked up, my exhaust is somewhat loud at the moment. As a partial short-term solution to having the neighbours wanting to kill me when I fire up the beast in the mornings, if she idled at 700rpm when cold, as she does when she's warm, instead of the current 1200 or so, the noise would be dramatically reduced.
Anyone know if this is possible and, if so, how? Don't think VCDS/Vag-Com will help, and maybe not Lemmiwinks either. :?
Hi, Engine revs are higher for a reason as cold engine mixture requires to be richer, will probably stall if revs are lower.
Do the neighbours worry about you.? :wink:
1 - 3 of 3 Posts
