1 - 20 of 26 Posts
Iv just ordered a tts and Iv seem on the Audi a5 and mercades cars that when you lock the door the DRL come on
Is this an option for the tt?
Blacknerd said:
Yes, with auto lights I believe.
there's no auto lights option on the TT
Funny as we have them.
Not sure if you can use the DRL's as CH/LH lights but you can certainly use the headllights or foglights (better idea when you have xenon's)
Not sure if you can use the DRL's as CH/LH lights but you can certainly use the headllights or foglights (better idea when you have xenon's)[/quote]
Only the drl, fog lights and the rear lights come on when CH/LH is activated. This can be done through the DIS.
You can use VCDS to select the headlights
(our car has no independent DRL's)
Only the drl, fog lights and the rear lights come on when CH/LH is activated. This can be done through the DIS.[/quote]
Does it come on all the time or only at night?
Does it come on all the time or only at night?[/quote]
All the time without the light sensor at night only with the light sensor.
Blacknerd said:
Is there anyway to make them come on all the time with the light sensor?
Why would you want ch/lh lights coming on all the time?
Mine comes on ALL the time when i open close my central locking. I have DRL headlights and xenons.
Auto lights? you mean that auto come on when dark? if so then no i don;'t
Blacknerd said:
So what about leaving home lights, when you lock the door does the light stay on for a specific time?
No that is for coming home lights.
Leaving home lights stop on for a set period when you unlock the car.
Discussion Starter · #18 ·
thanks Gizmo68, so is both leaving home and coming home included in the auto lights option?
Pretty sure they are yes (they are on most VAG vehicles) but our are both turned off so I would need to physically go into the DIS to check.
If you have DRL's and Auto lights with light sensor you can turn on leaving home/leaving home lights on the DIS. Lights set to Auto, unlocking/locking the car in day light... DRL's stay off. Unlock/lock the car in low light/darkness and the DRL's will come lighting your way too or from the vehicle.
1 - 20 of 26 Posts
