1 - 9 of 9 Posts
The numbers as such are not important (to a point), the important thing is that all 4 cylinders have pretty much the same compression.
Good luck andy.
From my own personal experience Of a similar build iwould suggest taking off the tip and looking for shaft play and oil coming through turbo. That is if you are still seeing misses under load :?
Wak said:
10-13 bar on each cylinder
7 bar minimum
3 bar max deviation across all cylinders
p.s. Thats 225 1.8T spec , dont know if a cylinder capacity change will change the numbers that are acceptable.
Matt B said:
Good luck andy.
Cheers Mat, I've basically stripped all the hosing and checked for Blow through and found nothing, Can't see any shaft play either so should be ready to get a custom file set up on the ECU for it and get rid of REVO once and for all :)
The Missfire was done to the RS4 Maf I'm postive on that as its all perfect with the TT Air flow meter on.
1 - 9 of 9 Posts
