Just trying to see what sort of builds people have done and maybe pick your
"BRAINS" as this is something im eyeing up myself so was considering what
would be a good setup for my needs
So this is the little bit i know
(For the people who dont know the crank creates a "stroke" is basically how far the pistons travel
up and down the block from the crank rotating)
Stock 1.8t Crank
Stroke 86.4mm
bore sizes for pistons 81mm 81.5mm 82mm 82.5mm 83mm
i think there is a bore size to 83.5 but people seem to go for 82.5mm or 83mm
and its 83mm is what gives a true 1.9ltr bore but allot seem to go with 82.5
not quite sure why ?
2.0t Tfsi crank
will give you a stroke of 92.8mm and combined with 83mm pistons
will give you 2008cc same bore size as the 1.9 stock crank but its the
TFSI crank what increases to the 2ltr because of the longer stroke
So hopefully i got that right ? :lol:
Anyway when it comes to pistons i "hear" lower compression pistons allows
for increased boost and timing but seems a few have opted for higher
compression pistons what may aid quick spool? this is what im after
is to enhance quick spool further with my hybrid at lower rpm so was thinking
83mm bore with higher compression pistons
what setups have you got Any thoughts ?
Sorry if i made a meal out of this question i was bored :lol:
Stock 1.8t Crank
Stroke 86.4mm
2.0t Tfsi crank
