Hi all. I tried to get an answer from previous threads but can't seem to find any help. Also this site has saved me loads of cash by searching and diy thank you all.
So here is my problem. The drivers side(right hand side drive) dipped beam does not work. The other side works good. I have checked the bulb and it is fine. Fuse blown but it keeps burning out. So I have unplugged the headlight unit and fuse still burns.
I than proceeded to unplug the headlight switch and still a short occurs. Lastly I unplugged the relay. And still a short on the dipped light.
So the only place left to look at is the wiring harness for short or the ecu?
Any spitballing or ideas would be appreciated.
And no I haven't plugged a diagnostic tool in the obd. I don't have access to one now.
Thanks.
Thanks.
