This is kind of a how to guide (of the amateur level
but i gotta start somewhere
) - its is a very simple guide with lots of pictures, i used this more as an entry level guide for myself as its very straight forward to figure out, but if anyone is unsure this may help.
TOTAL TIME -20minutes
The Engine bay as was, with broken dip stick handle and cracked tube.
Close Up - here you can see the two Bolts to the left and right and the sensor in the middle all of which need to be removed
Remove Sensor
Alan key head 5.5
Remove bolts and then the metal plate
Remove the old tube attached, with the dipstick as it was stuck!
Good opportunity to degrease this plate
With the tube removed i noticed the old tube has literally broken off around and INSIDE the pipe
so i had to be extra careful removing both parts.
The outside of the tube -luckily - was cracked and so peeled away with a little pressure from the outside of the tube leaving only the inside ring in the tube. To test if it was STUCK or not i stuffed a microfibre in the tube and then basically pulled it out, as i was pulling the whole inside ring just slide right out, otherwise you would need to put some tissue or something down the pipe to avoid any small bits of broken pipe falling down the tube.
Once removed - wipe around the pipe with some clean tissue.
Simply push on the new tube making sure it is on nice and tight
Pop the plate back on - hooking it through the yellow holder and line up the two bolts
tighten bolts and attach sensor
re-attach cover and insert new shiny dipstick
Tools Used (may vary depending on where yours snapped and what you have available - this was all i had available and done the job fine
Old tube and stick with new for comparison
9 euros for new tube and stick from Cyprus dealers
Remove Sensor
Alan key head 5.5
