1 - 3 of 3 Posts
Bought a bottle of this stuff to try instead of using the trusty old Autoglym SRP.
Turns out they do a 'lite' version, should I have got this instead to use on a low mileage 3.5 year old car rather than the full fat version? Bit worried that I may be cutting down too much as it were before I re-wax (using Dodo Juice Diamond White btw).
Get the idea of the net that in most cases Audi paint is hard, so assume that the normal lime prime would be Ok. Anyone here used this with no problems? Will be applying it by hand,
DoDo Juice Lime Prime by hand on Audi paint will remove pretty much nothing mate, you're fine.
I use it all the time, even by DA/Rotary you will be hard pushed to remove anything from the Audi with it.
Thanks for confirming mate. 8)
1 - 3 of 3 Posts
