John-H said:
Just post up which torque figures you're after
Thanks John!
Torque figures are for suspension components on a late 2005
FWD TT 187PS:
Front suspension strut piston rod nut -
60Nm (New nuts)
Anti-roll bar connecting link to strut -
90Nm (New nuts)
Hub clamp bolt around strut -
60Nm + 90 degrees (new bolts)
Rear damper bottom mounting bolt -
40Nm + 90 degrees (New bolts)
Rear damper top mounting plate bolts -
30Nm + 90 degrees (use new bolts)
Rear damper piston rod nut -
25Nm (replace)
Thanks in advance.
Alan W
