after the pump, either you 3 port valve is letting by (y plan system) or one of your zone valves are letting by (s plan system) either way they will need to be replaced!!!Major Problem said:redsi,
I promise not to hijack your thread, but can anyone tell me the normal position of a 'diverter valve' in a domestic system?
My hot water setting is suddenly heating my rads too! :?
We have one of the 15-60 pumps for our system.Fairly large house but there are 3 flow settings on the pump so you can alter the flow rate from low-med-high.So should be ok for 4-5 bed house set at medium...but if you boiler is knackered then most new boilers have integrated pumps.hope this has helped some?redsi72 said:Hi,
my pump is on its way out. I was thinking of replacing it with a Grundfos Alpha Pro 15-60.
Has anyone had any experience of/with these pumps.
Thanks in advance,
Simon
Wow, that might just be my answer. I've tried a heating/hot water test and can't get the A-B indicator to move, so either it's lost its power supply or I've got a dead 3-port? Thanks for your help.alibTTman said:after the pump, either you 3 port valve is letting by (y plan system) or one of your zone valves are letting by (s plan system) either way they will need to be replaced!!!
take a pic of valve and post it up i may be able to help you with a simple solution!Major Problem said:Wow, that might just be my answer. I've tried a heating/hot water test and can't get the A-B indicator to move, so either it's lost its power supply or I've got a dead 3-port? Thanks for your help.alibTTman said:after the pump, either you 3 port valve is letting by (y plan system) or one of your zone valves are letting by (s plan system) either way they will need to be replaced!!!
redsi, you have a couple of pm's - cheers Mate!![]()
