Following on from my previous post :
http://www.********.co.uk/ttforumbbs/vi ... p?t=111704
All of the parts for the kit are now ready
This kit will replace all of the plastic rivets and the screws used to hold the front trim, battery cover and coolant cover.
All of the parts are top specification, no expense has been spared as I wanted to put together the best parts possible.
The threaded blocks are Aluminium with chamfered holes and hand finished M6 threads.
The bolts are grade A2 Stainless Steel or High Tensile Steel with a black finish
The rivets are aluminium with steel mandrels
The washers are CNC machined Aluminium with a hard anodised finish in silver or black. The surface finish is absolutely flawless.
All of the parts are machined in the UK !
Here is the complete kit :
6 x thin machined washers - for the front trim panel
4 x thick machined washers - for the battery and coolant covers
6 x threaded blocks
6 x 12mm Bolts in Stainless Steel or High Tensile Steel
4 x 25mm Bolts in Stainless Steel or High Tensile Steel
12 x Aluminum rivets
1 x Allen Key - standard 4mm size for the tool tray in the boot 8)
The threaded blocks are riveted in place and when installed they allow you to use a bolt to secure the front trim panels. The battery and coolant covers are simple replacements ie. remove the old bolt and replace it with a machined washer and new bolt.
This kit will fit proper TT's (ie not the mk2's :wink: ) 150, 180, 225 & V6 models.
From the excellent response from my previous post, I have arranged enough parts to make 40 silver sets and 10 black sets. Buying all of the parts in bulk has brought the cost of each complete kit down to £45.00. I can arrange insured P&P within the UK at £48.00
if you want a kit posted out ASAP, please send £48.00 via Paypal to [email protected]. Please make sure you mention your forum name and also what colour washers and bolts you require.
Alternatively if you want to pay by cheque just email me for my postal address.
UPDATE:
Please download the fitting instructions from HERE
UPDATE 19th April :
only a few kits left in Stainless Steel & in Black, get them while they are available!
6 x threaded blocks
UPDATE:
UPDATE 19th April :
