1 - 3 of 3 Posts
1999 TT 225 with ESP Haldex
Light on the instrument panel does not light up when ignition is turned on . Took dash pod out to check bulbs but they are LEDS on circuit board. Scanned for codes but no codes stored or pending.
Pushing ESP button does nothing. I have checked the multi plug under the car all ok , i have checked for fuses but the 31 does not have a fuse or cable coming out of the fuse holder and can not see another marked as ESP or HALDEX.
While i was under the car i also could not see a earth strap from the diff the the car body, although i did put a temp strap on but no difference.
Is there and more tests i can do?
Any help is much appreciated :)
1 - 3 of 3 Posts
