Status
Not open for further replies.
2007 3.2 VR6 Roadster
01317 - Instrument Cluster (J285): No Communications
Possible Causes
CAN-Databus Wiring/Connectors from/to Instrument Cluster (J285) faulty
Fault(s) stored in Instrument Cluster (J285)
Possible Solutions
Check CAN-Databus Wiring/Connectors from/to Instrument Cluster (J285)
Check Measuring Value Blocks (MVB)
Usually Measuring Value Blocks (MVB) 125+ show the current Communication Status
01317 - Instrument Cluster (J285): Check DTC Memory
Possible Causes
Possible Solutions
Check Instrument Cluster (J285) for Fault Codes
Special Notes
Instrument Cluster (J285) stored a Code which influences other Control Modules Functionality
01317 - Instrument Cluster (J285): Implausible Signal
Special Notes
When found in Audi A3/S3 (8P): Heating/Air Conditioning, check Instrument Cluster for Fault Codes.
May be stored in Combination with 00003 - Control Module / 005 - No or Incorrect Basic Setting / Adaptation in the Instrument Cluster.
It has been reported that for the Mk2 (8J) pulling Fuse 33 or disconnecting the battery ground cable and waiting a few minutes can sometimes, but not always, reset the unit.
In the UK, there are a number of repair shops that specialize in these repairs, here's a few you can check out. NOTE - This Forum does not promote or endorse any of them. This list is simply provided as a convenient reference -
https://www.ecutesting.com
http://www.clusterrepairsuk.co.uk
https://cartronix.co.uk/
https://totaltronics.com/
For a DIY on how to remove the Mk2 instrument cluster, follow this link -
For information on Cluster Swapping in Vehicles without Immobilizer -
https://www.ross-tech.com/vag-com/cars/ ... pping.html
Status
