1 - 4 of 4 Posts
18058- powertrain data bus missing message from instrument cluster
Any ideas what could be the cause of this fault code
Could this be down to my engine check light leds not working
Any input would be great. Thanks
Check all your fuses first ; )
It's not getting power by the sound of it or part of its not getting power
1 18058/P1650/005712 - Powertrain Data Bus: Missing Message from Instrument Cluster
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Possible Solutions
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fuse(s) faulty
Databus Wiring and/or Connector(s) from/to Instrument Cluster (J285) faulty
Possible Solutions
Check Fuse(s)
Check Databus Wiring and/or Connector(s) from/to Instrument Cluster (J285)
Check/Replace Instrument Cluster (J285)
Check Measuring Value Blocks (MVB)
Category: Fault Codes
1 - 4 of 4 Posts
