1 - 3 of 3 Posts
Hi everyone,i have got a 51 plate 225 coupe with 75000 on the clock. I seem to have a problem with the fuel gauge. The needle wont go above 3/4 full although when you put petrol in the pump cuts out as if the tank is full! The computer readout seeems to be correct ie around 330 miles worth of fuel. Also the needle seems to move when you go round a bend as if the float is faulty in the tank!
Any ideas anyone?
Thanks Lamps
Hi Lamps, If the Fuel range (miles left) shows the same wrong reading as gauge it's usually the senders (2 off them)in the tank, otherwise a dash pod prob.
1 - 3 of 3 Posts
