1 - 5 of 5 Posts
Hi guys
Just a quickie. How easy is it to fit new front discs and pads? Do I need any special tools or anything else apart from the discs and pads themselves?
cheers
Lee
Impact screwdriver for removing disks or you maybe lucky and get away with penetrating spray and a screwdriver, but you need a wind-back tool for the rear calliper's deffo. Cheap enough off the bay, I have one brand New as it didn't turn up in time and borrowed one from work.
Remember to remove the brake fluid cap and use a syringe and take some fluid out into a clean container, as when you push the pistons in the fluid will rise and overflow :(
Unless your reservoir is at the brim you shouldn't have a problem with overflowing.
Process of removing them is fairly simple, but they can be stuck on hard. I had a mechanic friend do mine, and I'm glad I did, as it would have taken me forever to find all the screws and get everything on and off in the right order.
1 - 5 of 5 Posts
