1 - 11 of 11 Posts
Hi all,
I decided to see if there were any stored codes on the car. Plugged in the software and 6 codes came up. I cleared them, went for a drive and one came back:-
17746 - Camshaft Position Sensor (G40): Open or Short to Plus
P1338 - 35-00 - -
Now the Timing chain, tensioner and water pump were all done 2 years ago at 80,000 miles.. (Currently at 90,000 miles)
Any thoughts on how I can repair this issue?
Car runs fine, although it is new to me so I don't know any different.
leholtet said:
I got the same error, and i replaced the sensor. Everything worked out :) Its easy to swap!
Been looking at any how too's on here to replace the cam sensor.
Nothing pops up.. I don't even know where the sensor is located .
Helpers ?
Its under the black camshaft cover out of sight top of this photo is the left hand side of my engine with the charge pipe removed
here is a scan of the bentley manual showing its location
Item 28 under the cambelt cover left hand side of engine
avalable from ebay for £10 odd check your part number BEFORE you order to make certain you get the correct one
http://www.ebay.co.uk/itm/VW-Audi-A...arts_Vehicles_CarParts_SM&hash=item3a61a186a1
hope this helps :p
I decided to get familiar as to where the cam sensor is for future replacement.
AS i said before the belt/pump/tensioner was all changed about 2 years ago.
Guess what I discovered today:-
Cam sensor wasn't even connected !!
Nick 225TT said:
So you had been driving with it out for some time or did the code just come up
Seems strange the wire clip should hold the plug in tight :?
Oh well all well that ends well :p
i bought the car last week, so I assume it has been off since the last time the timing was changed (2 years ago)
Unsure what implications it has on the car if not connected.
Would run in limp mode to protect the engine I would think what do you think WAK :?:
1 - 11 of 11 Posts
