1 - 3 of 3 Posts
I'm trying to fit a Clarion aftermarket music and Sat Nav unit, it's all connected and working..... but,
I can't get the unit slid back far enough due to the wires.
What's the easiest way to get a hand in to the back to make space.
I've been messing about for 2 hours trying to sort it.
Thanks,
John.
try the glove box or the panel under the steering wheel
There is quite a lot of room behind and down to the left (as you look) behind the radio/glove compartment. It can be narrowly accessed from the shelf below the glove compartment but not sure if you can fit your hand through there. I found you can push the cabling down into the void but you may want to wrap the connector plugs in cloth or rubber tape to stop them rattling against the side of the glove compartment.
1 - 3 of 3 Posts
