Strange materials indeed - some sort of compressed fibre stuff, probably 'green' and recyclable.huggy said:Very impressive - cant knock the dedication.
what do you put on that to get that finish - insiude the wheel arches is a strange material - like pressed board stapled together..
err.. you sure about that?VicTT said:Excellent stuff for wheel cleaning, citrus based so no nasty acids to attack your wheels.
Yup. As recommended by the forum cleaning magician Jac-in-a-box.oli660 said:err.. you sure about that?VicTT said:Excellent stuff for wheel cleaning, citrus based so no nasty acids to attack your wheels.
Rebel said:Mozes, get a life dude :lol:
I was referring more to the statement.. if something is citrus based, surely that implies it contains citrus acid which would in turn react to the metal?VicTT said:Yup. As recommended by the forum cleaning magician Jac-in-a-box.oli660 said:err.. you sure about that?VicTT said:Excellent stuff for wheel cleaning, citrus based so no nasty acids to attack your wheels.
Of Viro Sol, under the heading of "Wheel Cleaner"he says:
Brilliant stuff; for heavy soiling spray on neat and allow to soak for 5-10 mins and hose off - stubborn deposits may need a little agitating. Normal soiling dilute 1:10 with water and apply as above. It wont damage the wheels finish or brakes unlike some acidic products. 50 litres of wheel cleaner for around £6
Don't use it on the paintwork - it'll strip the wax off (wont damage the paint though) and don't use it on the leather. Otherwise its fine just about anywhere
Ah yes but I did say "no nasty acid" And I was comparing to a product such as Wonder Wheels which contains Hydrochloric acid and Phosphoric acid (total acid content 5%). I don't think many on here will want to be using that on their wheels.oli660 said:I was referring more to the statement.. if something is citrus based, surely that implies it contains citrus acid which would in turn react to the metal?VicTT said:Yup. As recommended by the forum cleaning magician Jac-in-a-box.oli660 said:err.. you sure about that?VicTT said:Excellent stuff for wheel cleaning, citrus based so no nasty acids to attack your wheels.
